Old 11-19-2009, 04:15 PM
Ramrob Ramrob is offline
Vehicle: 1999 Dodge Ram 1500 5.9L
Rep:75
Ramrob will become famous soon enough
Default My own rear lift level
I was going to have new 2500 brackets welded on and use a set of 04' leaf springs that I bought with intensions of gaining some spring back and something that could handle a load. My springs squated when I put my z400 in it. I hated it. So I ended up using the bottom flat load spring and the 2 small stack ones. The 2500 springs were only a little wider so instead of going through the trouble cutting brackets off and buying new ones I just fabbed the 2500 u bolts. With this setup i had 2.6tons of cruched stone in it and they wouldn't let me leave the quarry with any more. Yes it did squat but the tires didn't go in the wheel well. Stock I got almost 1ton of dirt and the 275's were tucked right up there. They I flipped them so they had a good arc but I have gotten a few loads over 2tons since then. Still have the rest of the leaf springs if someone is looking to do something. I only want a couple bucks if your interested.
Stock
After
Old 11-19-2009, 04:31 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
Thumbs up
Great work and thanks for the photos. Not interested in the leafs but appreciate the time spent on the pics.
Old 11-19-2009, 04:36 PM
I push the skinny pedal
Rep:3277
Wow, you made that look good. Great way to beef up the 1/2 ton suspension.
Kurtis
Old 11-19-2009, 04:57 PM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
nice job!!!!
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
Old 11-19-2009, 05:27 PM
Rep:75
thanks since th bottom leaf was wider and I needed to maintain the width at the top, I cut a small notch in the ubolts, bent them in a press, then welded them again. After I painted them you couldn't even tell. My buddy asked where I bought them.
Old 11-19-2009, 06:29 PM
Just be careful the rest of the truck isn't set up to handle that kind of weight . Could see you snapping an axle , trashing a set of wheel bearings or trashing a rear .
Old 11-19-2009, 07:23 PM
Ultimateride14's Avatar
Ultimateride14 Ultimateride14 is offline
Vehicle: 2007 Dodge Ram QC 4x4
Color: Inferno Red
Ultimateride14 is on a distinguished road
Toms very right. Don't Overdo it. I've seen bad things happen to trucks over loaded. Are the 03's frames fully boxed. My 07 is and i wondered how far back they've had them fully boxed.
Old 11-20-2009, 09:53 AM
Rep:75
yeah mine is. my quarry is about 4mins from my house. I don't drive all around town loaded.
Old 11-25-2009, 12:51 PM
94beast's Avatar
94beast 94beast is offline
Vehicle: 94 dodge ram 1500
Trim Level: debadged
Color: green and black
Rep:14
94beast is on a distinguished road
thats like what i did! i got a set of 2500 2wd ones and it not only lifted my rear end, they were wider than stock ones so i was able to carry more
Old 11-28-2009, 10:05 PM
Rep:75
Did you just swap out the one like I did or did you use the whole thing? I was going to drill the center hole threw them and run my top leaf with the rest of the 2500 pack and decided not to after 2 $40 bits. The diamond tip ones were like $150-$200 for the size I needed. I also found a place about 40mins away that would drill them for $100.
