Old 11-19-2009, 08:49 PM
971500's Avatar
971500 971500 is offline
Vehicle: 1997 Dodge Ram 1500 4x4
Trim Level: Basic
Color: Emerald Green Pearl
Rep:16
971500 is on a distinguished road
Send a message via AIM to 971500
Default Rear Brake locking up
i have a 97 1500 with a 5 spd trans. I did the rear brakes and new hardwear and seals. I have a prob with the right side wheel locking up every now and then when I brake. It hasnt happeaned in the last few weeks. I took the drum off to see if it was damp in there and it was dry. I was curious if any one eles has had the same problem.
Old 11-19-2009, 11:21 PM
Are the shoes installed correctly ? Did you resurface the drums ? Are the shoes adjusted correctly ? Just a couple of questions . If your not sure , take a picture of the brakes and post them and I'll take a look at them .
Old 11-20-2009, 12:13 AM
971500's Avatar
Trim Level: Basic
Rep:16
i didnt resurface the drums cause they were new. and i did them one side at a time.i'll try to get some pics this weekend if its not raining
Old 11-20-2009, 12:15 AM
wagoner2's Avatar
wagoner2 wagoner2 is offline
Vehicle: 1994 Dodge Ram 2500 4wd
Trim Level: as base as it gets..
Color: Dark Green
Rep:58
wagoner2 will become famous soon enough
I have the same problem. I was just going to convert over to disc all the way around. Interested in seeing where this thread goes.
Old 11-20-2009, 12:21 AM
971500's Avatar
Trim Level: Basic
Rep:16
i thought my seals were leaking again so i pulled the drums the other day..everything was dry. but if it was the drum wouldn't both sides do this. it only happeans when i first hit the brakes a few times. like i said i'll take some pics this weekend...thanks for the help...Chris
Old 11-20-2009, 12:24 AM
wagoner2's Avatar
Color: Dark Green
Rep:58
It happens right after you start the truck and come to a stop the first time and maybe the time after?
Old 11-20-2009, 12:25 AM
971500's Avatar
Trim Level: Basic
Rep:16
yeah. i'm going to readjust the brakes on sunday i hope if its not raining
Old 11-20-2009, 12:30 AM
wagoner2's Avatar
Color: Dark Green
Rep:58
Let me know how it goes...
Old 11-20-2009, 12:31 AM
971500's Avatar
Trim Level: Basic
Rep:16
ok will do
Old 11-22-2009, 11:17 PM
Rep:1845
Sounds like you may have some condensation causing some light surface rust to form on the friction surface when it sits overnight.
