tonneaucovered.com
Old 11-20-2009, 01:00 PM
bloodninja bloodninja is offline
Gender: Not Specified
bloodninja is on a distinguished road
Default Off-Road Package in 2000??
Hi All,
I just picked up a 2000 Dodge Ram 1500 Sport Quad Cab, and I'm curious what the difference is with the Off-Road package available in 2000. What are the differences between my Ram and the Off-Road package Ram?
Thanks.
Jon
Old 11-20-2009, 03:01 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Originally Posted by bloodninja View Post
Hi All,
Thanks.
Jon
2 inch body lift, 17 in rims, and others. Mine is an 01 but should be the same
Here is my build sheet
Dear Luke:
Thank you for contacting the Chrysler Customer Assistance Center
regarding the build sheet for your 2001 Dodge Ram 1500.
We appreciate the time and effort you took to write to us.
In response to your email regarding the build sheet for your vehicle, we
would like to inform you that according to our records, your vehicle was
equipped from the factory with the following:
Premium Cloth 40/20/40 Bench Seat
Mist Gray
Light Group
Heavy Duty Service Group
Sport Group
Trailer Tow Group
Convenience Group
Monotone Paint
SLT Decor Group
Off Road Group
5.9L Engine(EML)/4Sp Auto Trans(DGT)
136 Amp Alternator
750 Amp Maintenance Free Battery
Pwr Disc/Drum Rr Anti-Lock Brakes
11x2 Rear Drum Brakes
40/20/40 Split Bench Seat
Front Height Adjust Shoulder Belts
Next Generation Front Air Bags**
Passenger Air Bag On/Off Switch
Deluxe Headliner
Front Seat Area Carpet
Front Floor Mats
Passenger Assist Handle
Passenger Assist Handles
Mini Overhead Console
All 4-Speed Automatic Transmissions
4-Spd. Automatic 46RE Transmission
Lock-Up Torque Converter
Shift-on-the-Fly,231HD Transfer Case
195MM Front Axle
4.10 Axle Ratio
Corporate 9.25 LD Rear Axle
Anti-Spin Differential Rear Axle
All Engines
All Gas Engine
5.9L V8 MPI Engine
Tinted Glass Windows
Rear Fixed Window
Rear View Day/Night Mirror
Passenger Side Sun Visor w/Mirror
Power Heated Mirrors, Fold-Away
All Vehicles W/Power Mirrors
Remote Keyless Entry
Air Conditioning
Hood Insulation
Dash Liner Insulation
Instrument Cluster w/Tach
120 MPH Primary Speedometer
Var Intermittent Windshield Wipers
Cigar Lighter
Dual Note Electric Horns
12V Auxiliary Power Outlet
Power Locks
Power Windows, Driver One-Touch
Power 8-Way Driver Seat
Power Driver Seat
Map/Courtesy Lamp
Glove Box Lamp
Underhood Lamp
Halogen Headlamps
Halogen Quad Headlamps
Fog Lamps
Cargo Lamp
Body Color Front Bumper
Body Color Rear Bumper w/Step Pads
Front License Plate Bracket
Body Color Grille
Black Windshield Moldings
Removable Tailgate w/Caliper Latches
Federal Emissions
EVAP Control System
26 Gallon Fuel Tank
Auxiliary Transmission Oil Cooler
Speed Control
Heavy Duty Engine Cooling
Intense Blue Pearl Coat
All Radio Equipped Vehicles
AM/FM Cassette Compact Disc Radio
Infinity Speakers
Fixed Long Mast Antenna
Steering Wheel Mounted Audio Ctrls
Power Rack and Pinion Steering
Leather Wrapped Steering Wheel
Front Heavy Duty Shock Absorbers
Rear Heavy Duty Shock Absorbers
Front Stabilizer Bar
Tilt Steering Column
Full Size Spare Tire
Tire Carrier Winch
LT275/70R17 OWL On/Off Road Tires
Goodyear Brand Tires
17X8.0 Aluminum Wheels
Steel Spare Wheel
Center Hub
Pickup Box
50 State Emissions Tracking
Vendor Painted Cargo Box
Tow Hooks
Fuel Tank Skid Plate Shield
Transfer Case Skid Plate Shield
Without Billable Fuel
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
Spring - Right Front
Old 11-20-2009, 04:42 PM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
That is a sweet Ram!
