Old 11-20-2009, 06:02 PM
SPEEDFREAK's Avatar
SPEEDFREAK SPEEDFREAK is offline
Vehicle: 2010 RAM R/T
Trim Level: 450HP & 450TQ
Color: SPEED WHITE
Rep:180
SPEEDFREAK has a spectacular aura aboutSPEEDFREAK has a spectacular aura about
Default Were to buy 180 therma & how to remove clutch fan?
Have 09 ram 5.7 want to buy a good 180 deg thema and want to remove the clutch fan for more power, how to remove ? Thanks
k&N CAI, 3 1/2" 90 on CAI at TB, 85mm BBK TB,denso sp,180stat,syn oileng & rear gr,Catchcan, Addco sway bars f&r
1 3/4"amer rac hders high flowcats, 2 1/2" H pipe dul 2 1/2" piping, Diablo CT, Bilstin, Mcdrop 2/4,1deg cam 295/45-20bfgkdw,efan,13.4gtech
Old 11-20-2009, 09:56 PM
I push the skinny pedal
Rep:3277
You can order/get a 180 deg thermostats from your local parts store. Since you're removing the clutch fan are you getting an electric fan to replace it? Which are you looking at going with?
Kurtis
Old 11-20-2009, 10:13 PM
wagoner2's Avatar
wagoner2 wagoner2 is offline
Vehicle: 1994 Dodge Ram 2500 4wd
Trim Level: as base as it gets..
Color: Dark Green
Rep:58
wagoner2 will become famous soon enough
Thinking of doing the same to my truck, let me know how it goes...
Old 11-20-2009, 11:11 PM
Airdog's Avatar
Airdog Airdog is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Sport 4x4
Color: Detonator Yellow
Rep:37
Airdog is on a distinguished road
I'm with the other guys above. Get a good themostat at a auto parts store.
Most of 2009 Ram's don't have a belt driven "clutch" fan but do have an electric fan mounted behind the radiator.
The waterpump, a/c compressor, alternator, etc are driven by a serpintine belt. Apparently the R/T's have a viscous cooling fan.
I found a couple of pages in the 2009 Ram service manual that might help you out.
Good Luck!
~Airdog .
Old 11-21-2009, 07:54 PM
Airdog's Avatar
Rep:37
Doh! I hate when this happens, but I have to correct myself!
I looked under the hood a little more today and I noticed that my 5.7L Hemi
has a belt driven "clutch" fan buried under the radiator shroud. I knew better but after looking at
the service manual I assumed it wasn't there. I know the electric fan is there cause I here it kick in now and then.
Although I'm almost always right (just ask my wife...haha) as much as I hate to say it, I stand corrected.
Really, when is the last time you saw a V-8 without a clutch type fan? What was I thinkin????
~Airdog .
Old 11-21-2009, 09:45 PM
Rep:3277
Lol, it's ok Airdog.
I'd recommend one of the Flex-a-lite fans if you want to install another fan. If you want to lose the fan shroud and stock fluid bottles, talk to Moe at Moe's performance, he does a delete kit for the HEMIs. Picked one up for my '07 and it looks great. Also has the 180 deg thermostat option with the kit. Just an idea.
Kurtis
Old 11-22-2009, 03:11 PM
matt3 matt3 is offline
matt3 is on a distinguished road
Not to thread hijack but, what is the purpose of switching to a 180 degree thermostat? What degree thermostat is in there now?
Old 11-22-2009, 05:45 PM
Rep:3277
Switching will open the solenoid sooner (@180deg) and keeps the coolant and engine block at a cooler temperature so you have less parasitic heat loss. A cooler engine is a happy engine... to a point, as they're designed to run at a certain temp range for oil lube and metal expansion seal. I believe the stock therms are 196? correct me if I'm wrong though.
Kurtis
Old 11-22-2009, 05:57 PM
If it's that much better, why doesn't Dodge just put them in at the factory? There has to be a reason why the engineers decided to use a 196 degree thermostat
Old 11-22-2009, 07:08 PM
Rep:1909
Keep in mind that it is possible for a code to set in the PCM for the coolant not reaching operating temp fast enough.
