Old 02-25-2011, 08:21 PM
jwsnowman jwsnowman is offline
Vehicle: 2011 Dodge Ram 1500
Color: Deep Water Blue Pearl
Rep:27
jwsnowman is on a distinguished road
I talked to the parts and service guy at my dealership about ordering in a 180 t-stat for me and he said that it would cause an error code to pop up...I think he said that it would pop up in the winter months (I'm in Nova Scotia) Has anyone else had this problem in a similar climate? If I go with the t-stat should I also put in an electric fan for it to work properly? Also, will any of this void the factory warranty?
Thanks guys!
Old 02-26-2011, 05:54 AM
rtkman's Avatar
rtkman rtkman is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Rep:167
rtkman has a spectacular aura aboutrtkman has a spectacular aura about
I would hook up a second e fan to come on with the one that's already there. (its the a/c fan actually) You could tap into the live wire to that fan with a relay and power the other fan directly from the battery with a fuse of course. Using the relay and power from the existing fan to trip the relay thus pulling power direct. I would think you would see some fuel savings doing this.
Old 02-28-2011, 09:07 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Where would you put an extra fan?
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 02-28-2011, 08:23 PM
rtkman's Avatar
Rep:167
I dunno. I haven't thought it through
Old 06-22-2011, 08:17 PM
cmhendrix1280 cmhendrix1280 is offline
Vehicle: 2009 Dodge Ram Hemi CC BigHorn
Trim Level: Big Horn SLT 4x4
Color: Detonator Yellow
cmhendrix1280 is on a distinguished road
Did we ever find out about summer months with no clutch fan???
Old 06-24-2011, 09:49 PM
thumbuster2 thumbuster2 is offline
Vehicle: 09 Dodge Ram 1500
Trim Level: SL
thumbuster2 is on a distinguished road
Fact of the matter is most of the big rigs i have seen and worked on do have either an electric or air operated fan clutch
Old 06-26-2011, 02:07 PM
Second Life's Avatar
Second Life Second Life is offline
Vehicle: 2011 Ram 1500 Crewcab
Trim Level: Outdoorsman 4x4
Color: Deep cherry red
Second Life is on a distinguished road
Originally Posted by smarthead2006 View Post
180 is not good for trucks, we ran in to theses when guys would come in the shop with their "rigs" and they thought that their "CAT" was running to hot, we would told by "CAT" that running at 180 would not be good for the motor over time due to not reaching " Efficient operating temp"
A thermostat sets the minimum operating temp - not the norm.......
The heat removed is a matter of the output of the engine, what the radiator and rest of the system can remove. So actual operating temp will depend more on the abilities of the cooling system (rad, fan, etc.) and what the engine puts out and not really on the stat.
But Airdog,
There are V-8 out there with no fan belt- That only use Electric Fans (But not on Trucks!)
the 06 and Up FORD Crown Vic, Mustang
With a truck, i would not just trust a electric fan!!!
Think about, On Big Rigs if the electric fan would work don't you think they would put it on them, to save on Fuel, Belts, Noise and Horsepower ????
Just my thought, i am not there to hurt anyone's feeling
2011 F150 come stock with e-fan. Maybe even 2010.
Truxedo LoPro - Westin Premier 6'' Oval tubes - Sonnax line pressure booster - Dee Zee rubber bed mat - Magnaflow 12259 - K&N Aircharger - Bilstein 5100 set at 2.8'' - BullyDog GT for Hemi Plus
Old 06-27-2011, 02:35 PM
RamTex's Avatar
Color: Stone White
Rep:366
My truck runs fine no problems at all in the heat stop and go when ever... and no clutch fan! But i dont pull stuff so if you do haul trailers i would keep the clutch fan for sure until a good kit comes available.
