Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Dodge Ram Decals
Old 11-21-2009, 12:54 AM
xjarhead69 xjarhead69 is offline
Vehicle: 1996 Dodge Ram
xjarhead69 is on a distinguished road
Default Auto to Manual trans conversion?
Ok tranny in my 2wd 5.2L 96 Ram died this week. Looking at all options here.
One is to convert to manual trans, but besides the obvious tranny, flywheel, clutch, driveshaft, shifter, peddle assembly, hydralic resivor and slave cylinder and hoses. What else would i need? ECM? PCM? Any help would be great. Has anyone done this?
Thanks Dave
Old 11-21-2009, 11:01 PM
Probably wouldn't be a bad idea on the ecm . Your original computer would be looking for inputs from the original trans sensors . I would just wire tie the original wiring up . Don't cut it out , leave it there . To do it correctly you would probably need a steering column also .
Old 11-22-2009, 02:19 AM
Good idea on steering colunm. I would probably change ECM. I guess I should start looking for donor truck.
Thanks for the help.
Old 11-22-2009, 10:57 AM
Thats the only way to do it . That way you have everything there you need .
Old 11-23-2009, 07:59 PM
95laramie318's Avatar
95laramie318 95laramie318 is offline
Vehicle: 1995 Dodge Ram 1500
Trim Level: SLT Laramie
Color: Two tone Red on Silver
95laramie318 is on a distinguished road
You'd also have to put gauges out of ram that had a manual trans, so the gear selector wouldn't be there
LYNCH AREA FIRE DEPARTMENT AND EMS
