Old 11-21-2009, 09:36 PM
rammin her rammin her is offline
Vehicle: 2003 dadge ram 1500 qc 4x4
Trim Level: laramie
rammin her is on a distinguished road
Default dodge ram 1500 reg cab removal of rear speakers
I need to get at the speakers in the rear of a 1500 reg cab. in know i have to take of the seatbelt on the pillar to do this but i am feeling catious about doing it any one replace their rear speakers that can give me tips would be much appreciated.
Old 11-21-2009, 09:37 PM
Trim Level: laramie
the year is 2005
Old 11-21-2009, 10:06 PM
I push the skinny pedal
Rep:3277
Removing the seatbelt bracket is actually quite easy. A T-50 bit on a ratchet is all you need; assembly comes off and then pull off the pillar cover. Done. remove speaker with a phillips screwdriver and replace.
When you put the bolt back in, you can put some loctite on it, but I wouldn't recommend it. Just torque it to spec and you're good.
Kurtis
Old 11-21-2009, 10:09 PM
The rear panel is held with simple spring steel or plastic clips. Some firm pressure around the edges (don't yank it) will pop it off.
Old 11-21-2009, 10:41 PM
Trim Level: laramie
thanks for info. the bolt in the seat belt was really tight i was afraid of use too much force.
Old 11-22-2009, 01:46 AM
Rep:3277
The factory uses some thread locker, you just need to break that and it's fine.
Kurtis
Old 06-10-2013, 04:26 PM
Rambo Jr's Avatar
Rambo Jr Rambo Jr is offline
Vehicle: 2012 Dodge Ram
Color: Mineral Gray/Black
Rep:15
Rambo Jr is on a distinguished road
I just replaced my rear speakers in my regular cab too. The seatbelt bolt was pretty tight but I eventually balled up to give it just enough force it needed without stripping it. The panel is held in with clamps. Check out my video to help you install yours. They sound great!
2012 Dodge Ram 1500 RCSB 4.7L V8 | K & N Air Filter | 44 PSI | 265/70/R17 Goodyear Wrangler SR-A's
Old 02-01-2015, 04:13 PM
Aggie86 Aggie86 is offline
Vehicle: 2014 Ram R/T
Aggie86 is on a distinguished road
Nice video.
Old 02-01-2015, 05:45 PM
Hornet Hornet is offline
Vehicle: 2014 RCSB 8sp/3.21 geared Ram
Trim Level: Sport lowered 4X4
Rep:488
There's wire adapter harness's available Aggie that make the speakers plug-n-play now,with no cutting or soldering to the factory wire harness.
If you buy the spreakers through Crutchfield the adapter harness's are included with your speaker purchase.
He never does put the factory interior trim panel back on in the video though.
I'm swapping my 6.5" Kickers to the same speakers as in the video,wait a week or so,and i'll be able to tell you if the factory interior panel fits over them
Old 02-02-2015, 07:59 AM
That sounds good. The main reason I want to get to the speakers is that I'd like to tap them for the signal to install my Kicker Hideaway under the drivers's seat and thought this would be the easiest but have seen some posts on this and another forum saying that the rear speakers dont get a "full" signal and you should tap the door speakers. That sounds a bit odd to me. While I have them out doing the splicing for the signal for the Hideaway I may as well go ahead and do this upgrade.
speakers
