Old 11-22-2009, 01:15 AM
jjhwick119's Avatar
jjhwick119 jjhwick119 is offline
Vehicle: 2004 Dodge Ram Reg cab
Rep:97
jjhwick119 will become famous soon enough
Question About to hit 100k!
so i when i bought the truck, i had about 65k miles on her, did regular oil changes, occasional power steering ( had a problem... ) and up until reciently i always had a shop do my oil changes, and they always checked my other fluids (or so they say)
gonna hit 100k here soon. truck runs great, but i have no previous info on any maintenence done on her. i was told by someone that im supposed to do something to clean out my tranny..a flush or something..but that shop said they wouldnt do it because i didnt have records of any work ever being done and it could break stuff loose thats stuck in there that could mess up the tranny.
anyway...im just wondering what i need to do to make sure she keeps on runnin? truck didnt come with a service manual so im clueless, and like i said, as far as i know, only oil changes were done. dealership said it was always up to date on tune ups and blah blah blah before i bought it, but u cant trust those guys so i dont know for sure if it was takin care of
04 Dodge Ram 1500 SLT 2WD. De-Badged
Regular Cab, Black. drop shackles in rear to level
Old 11-22-2009, 01:18 AM
jjhwick119's Avatar
Rep:97
and i use royal purple oil right now, but i really hate paying that much for oil....
any suggestions? was considering going to a high mileage oil, but ive heard once u go full syn you cant do anything else
Old 11-22-2009, 02:02 AM
CdnoilRAM CdnoilRAM is online now
I push the skinny pedal
Rep:3277
They're right about doing a flush. Unless you plan on dropping the pan and doing a good clean yourself most places wont do it for that very reason. You can switch back to conventional oil, but it wouldn't make a difference. Running syn is the best thing for an engine at any mileage so long as all your gaskets are holding up.
Kurtis
Old 11-22-2009, 09:52 AM
I personally think that the bit about servicing a trans to late in it's life is a hoax . That it could break stuff loose .The inside of a trans is spotless . Better to do it than not to do it .
Old 11-22-2009, 10:57 AM
jjhwick119's Avatar
Rep:97
alright, well im kinda retarded when it comes to working on cars. interior doing audio, thats my thing. under the hood...im a complete newb. i just learned how to change my oil a couple hundred miles ago, and ive had the truck 2 years.
what all is involved in a flush? and im assuming i need spark plugs. how hard are those to do? anything else involved with doing those that i should check to see if they need replacing as well??
sorry, im under-the-hood-retarded
Old 11-22-2009, 11:08 AM
Trans flush ? I would drop the trans pan , install a new filter or filters , reinstall the pan and fill with fresh trans fluid . Plugs aren't to bad to do . Don't buy into the 100,000 mile plug bit . If you leave them in there that long when it comes time to replace them you have a extremely hard time removing them . They don't put antiseize on the plugs from the factory . Most of the newer engines have coil packs on them . You'll need to remove them , then you can get to the plugs . I make it standard practice on everything I tune up to put a wrap of antiseize on the threads of the new plugs .
Old 11-22-2009, 11:46 AM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
i would flush the transmission its not going to hurt!!
as far as 100k she has alot of life left!!!
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
Old 11-22-2009, 12:27 PM
Stay away from that shop. They just told you that so they didn't have to tackle the job. That's total BS.
Here's some things to consider doing:
Trans flush and new fluid,
differential fluid replacement,
PS system purge and fluid replacement,
coolant system flush and new coolant,
EGR valve replacement,
check all body mounting bolts,
O2 sensor replacement,
inspect front wheel bearings and replace as necessary,
inspect brake pads/shoes, rotors and drums,
brake system fluid replace and bleed system,
check all suspension fasteners and
generally inspect the vehicle, top to bottom.
Old 11-22-2009, 01:09 PM
RockyRam's Avatar
RockyRam RockyRam is offline
Vehicle: 2014 Ram
Color: True Blue
Rep:851
RockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to behold
Send a message via AIM to RockyRam
Take a pict when you flip over!!
Have a Gray Ram?? Join the Mineral Gray Metallic Ramz Group!!!
http://www.ramforumz.com/group.php?groupid=21
Old 11-24-2009, 12:04 AM
jjhwick119's Avatar
Rep:97
bout to show just how much of a newb i am...
i have no idea where the spark plugs are, lol. thats how i little i know. any chance someone could take a pic under their hood and point me in the right direction?
is the transmission pan under the truck like the oil pan is? seems like thought shouldnt be too hard for me to do.
power steering and brake fluid was alrdy done after i got into a wreck and had to the get the whole front end replaced (or so they told me)
