Gas/air/electric??? problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
Old 11-22-2009, 07:17 PM
snowplowguy snowplowguy is offline
Vehicle: 1994 Ram (v10), 1997 Ram(v8)
Trim Level: ???
Color: green
snowplowguy is on a distinguished road
Default Gas/air/electric??? problem
Hey all, I bought a 1997 ram, got a great deal but need to get it running better. I think the guy that owned the truck before was trying to fix the same problem but gave up and let it sit. It drives decent but when it gets to the end of the gear it starts powering down itself and when you push the gas in further it starts popping like popcorn, my buddy said that its backfiring. When you push the pedal all the way down it will switch gears but only if it hits passing gear. It feels like its going to stall sometimes in idle but its intermitent. The code keeps says it needs an 02 sensor but one of my friends says that's because there's no cat on it. The computer's also saying that it's running rich. There was some kind of short on the wiring harness where 6 wires got burned up. As near as I can tell the wires mostly go to the daytime running light module that was fried but I haven't figured out if that's all the wires were for yet. Went to 6 junkyards looking for a daytime running light module and finally found one but the year must have been different because the wires were different colors so I didn't end up hooking it up and capped the wires so that they wouldn't short or drain the battery. I know that's a lot of info but I'm not sure what to try next. Already did new brakes, rotors, brake lines, pulled the tank and looks like fuel filter's fine, new plugs, new wires, new air filter, so I have some time and money into this truck already but I'm lost now. Any help would be greatly appreciated.
Old 11-23-2009, 12:06 AM
Wasn't aware that there were DRL on our trucks . Knew it was more common on the newer trucks . Got any pics of the burnt up wiring harness ?
Old 11-23-2009, 12:09 AM
Trim Level: ???
Color: green
I'm pretty sure 97 was the first year they put it on, but I don't think it was on all of the 97's, no pics yet. I tried to get the connector to the DRL but the dealership only wanted to sell me the whole wiring harness for the truck and they wanted $500 for it.
Old 11-23-2009, 12:11 AM
I don't think I have ever seen a older Ram with DRL's .
Old 11-23-2009, 12:40 AM
Resident Technician
Rep:1915
The dealer can order the connector itself, but not as a pigtail assembly. Your best bet is to scour the salvage yards and get one and splice it into your truck.
Old 11-23-2009, 08:05 PM
Trim Level: ???
Color: green
I got one after the 6th junkyard, and it turned out to be a different year. The DRL module was the right part number but the wires were different colors, I'm going to have to get a new chilton manual to figure out the wiring, the one I have only covers up to '96. Any clue what else would cause this besides the wiring?? I'm thinking like a throttle control or something not allowing it to shift at the right time.
Old 11-24-2009, 01:26 PM
Resident Technician
Rep:1915
You need to get the engine problem diagnosed before you go after any transmission issues. Chances are fixing the engine will remedy the shifting issues. which O2 codes are you getting? Upstream codes shouldn't set for the cat being gone, but downstream codes will.
Old 11-25-2009, 05:39 PM
Trim Level: ???
Color: green
Thanks for the help, you got me thinking now. I took 02 sensor to mean it senses the airflow to tell how the engine's performing, I didn't realize it tells the computer what to put out. Now you've got me wondering if that wire got fried with the daytime running light module. I need to check the wires again and get the wires and the 02 sensor problem solved.
