Old 11-22-2009, 07:23 PM
YoMoma's Avatar
YoMoma YoMoma is offline
Vehicle: 2001 Dodge Ram 1500 4x4
Trim Level: Laramie SLT
Color: Green
Rep:18
YoMoma is on a distinguished road
Default Sqeaky frontend
Got a squeak somewhere in the front wheel suspension. My bro thought maybe it was dry u-joints. Didnt see anything other than driveshaft u-joints in my Chiltons book.
Immediatly after taking off from a stop, I hear a squeak that gets faster as the truck moves faster. It sounds louder when I`m giving it gas and quieter when I`m rolling to a stop.
Any adeas?
I`ll see if I can get a sound bite from my mobile phone sometime soon and post a link here.
Old 11-22-2009, 07:27 PM
I'd suspect a front wheel bearing or a front brake that is dragging.
Old 11-22-2009, 07:28 PM
971500's Avatar
971500 971500 is offline
Vehicle: 1997 Dodge Ram 1500 4x4
Trim Level: Basic
Color: Emerald Green Pearl
Rep:16
971500 is on a distinguished road
Send a message via AIM to 971500
Any adeas?
you have u-joints in the axel by the wheels...could be balljoints have someone get under the truck and bounce it
Old 11-22-2009, 08:42 PM
RamTech RamTech is online now
Rep:1845
Checking the temp of the u joints with an infared gun is a good way to find a dry u joint without pulling the axles or driveshafts out. Each cap should be withing a few degrees of each other. A higher temp on the caps indicates a lack of lubrication. Also check your backing plates for debris that might be trapped between it and the brake rotor.
