Old 11-23-2009, 01:07 AM
Marine671's Avatar
Marine671 Marine671 is offline
Trim Level: Limited 4x4
Color: Deep Cherry Red
Rep:105
Marine671 will become famous soon enoughMarine671 will become famous soon enough
Default 09 Ram Wheel size Q's???
This is something I've decided I want to do. I want to get the McGaughy's 2/4 drop on my Ram and stay with the same size wheels (20''). I want to get aftermarket wheels though and before I look into buying anything, I'd like to get myself educated about wheel offset. What is it, what does the 09 Sport model wheels have as an offset, and what are offset recommendations... All I know about wheels are rim size and tire width... Offset is totally foreign to me.
Old 11-24-2009, 01:18 PM
boosted20v boosted20v is offline
Rep:93
boosted20v will become famous soon enough
Send a message via Yahoo to boosted20v
offset is how far the face of the wheel sits either inside or outside of the rim. To make it simple take the letter "I" you could say the offset would be zero as the vertical line is directly in the middle of the horizontal lines. If the vertical moves left or right you end up with pos/neg offset. The easiest way to figure it out is to go to a wheel site ie: tire rack or discount tires and put you truck in. They will give you your stock offset and show you what wheels fit to give you an idea.
2009, offset, ram, rims, wheels
