Old 11-24-2009, 07:57 PM
I push the skinny pedal
Rep:3277
Good thought about getting the re-flash done at dodge then.
Kurtis
Old 11-24-2009, 08:17 PM
NEVRL8's Avatar
NEVRL8 NEVRL8 is offline
Vehicle: 2014 1500 Crew Cab Sport 4X4
Color: Maximum Steel Metallic
Rep:67
NEVRL8 will become famous soon enough
Originally Posted by smartel View Post
Gears and limited slip w/install kit from this eBay Store:
http://stores.ebay.com/RONS-MACHINING-SERVICE
$550.00 shipped, $65.00 for 3 quarts of Royal Purple 75W140 gear oil (already has limited slip additive), $105.00 to have Dodge re-flash PCM to correct the pinion factor, and $250.00 to a mechanic/friend. Probably would have been $450.00 for labor if I took it to the local gear shop.... So a total of $970.00....
If Dodge were to have done it, it would have been $2800.00 to $3200.00!!
I lost the warranty on my rear diff, but with the money I saved by not having Dodge do it, if it screws up I can do it again 2 more times and still not spend the same as it would have costed to let Dodge do it once!!
Thanks for the info. I am wanting to do this also. How sure are you that it will only effect your rear diff warranty? I was told if you changed anything mechanical in your drivetrain, it would void all of it. I know this can differ from one dealers opinion to the next, but I would like to know for sure. I have heard the aurgument that if it is not directly related to the part that failed then your good. I would still like to be 100% sure.
Old 11-24-2009, 08:19 PM
Rep:3277
Legislation for voiding warranty is the part has to cause the failure, not just be present.
Kurtis
Old 11-24-2009, 08:22 PM
lave80 lave80 is offline
Vehicle: 2009 dodge ram
Color: red
lave80 is on a distinguished road
I was told that if I do my rear then I have to change front also? It mAmes snce I have four wheel drive. If. Engage the front wouldn't it matter if the front has 3.55 yeas and the rear has 4.10's ?
Old 11-24-2009, 10:34 PM
Airdog's Avatar
Airdog Airdog is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Sport 4x4
Color: Detonator Yellow
Rep:37
Airdog is on a distinguished road
Man I hope you got a 2 wheel drive. That ^^^^ could cause some serious issues...
Oh, Congrats on the baby boy!
~Airdog .
Old 11-24-2009, 11:05 PM
iRockCrawler's Avatar
iRockCrawler iRockCrawler is offline
Color: Mineral Gray Metallic
Rep:44
iRockCrawler is on a distinguished road
I modified the T-case on my jeep to be twin stick.. shift front and rear independently. I can run 4HI, 4LOW, Front High, Front Low, Rear High, Rear Low.
But since I flipped it upside down as well, I wasn't able to interlock it. One time when going from 4HI to 2WD, I push the front leave a little to much. Front Low, Rear High and the jeep would not move at all and I could not shift either to neutral. Had to use a lifeline and call a friend to bring a jack.
LOL
Old 12-08-2009, 06:32 PM
LS Eater's Avatar
LS Eater LS Eater is offline
Vehicle: 2011 Ram Crew Cab Cummins
Color: Pearl White
Rep:12
LS Eater is on a distinguished road
Any change +/- on the MPGs? i was told it would get better with lower gears and our .67 overdrive ratio...
Old 12-08-2009, 06:45 PM
fuzzycali's Avatar
fuzzycali fuzzycali is offline
Color: Stone White
Rep:63
fuzzycali will become famous soon enough
Originally Posted by ls eater View Post
any change +/- on the mpgs? I was told it would get better with lower gears and our .67 overdrive ratio...
should be worse.hiway speeds especially.could b wrong tho.
Have a dropped RAM? Want too? Join our group.
Lowered RAMZ Owners Club/Houston Area RAM Owners Club
At some point the mod list gets too long.
Old 01-03-2010, 10:29 PM
will's Avatar
will will is offline
Vehicle: 2010 dodge ram quad cab
Trim Level: slt/bighorn
Color: silver
Rep:43
will is on a distinguished road
info on gears? take it to track? 0-60 times?
OLD TRUCK
NEW truck soon to be here
Old 01-04-2010, 10:24 AM
smartel's Avatar
smartel smartel is offline
Trim Level: Crew/Sport w/HEMI
Rep:47
smartel is on a distinguished road
Unfortunately, since the install, everytime I was going to the track it got rained out and now its closed. I think it will be open again for Test-n-Tune on Sundays during January starting on Jan 10. Then, starting in Feb, they'll begin opening on Friday nights also for bracket racing. I'm not sure when I'll be able to make it there, but I'll post some times when I do.
09 Crew Cab Sport, HEMI, Line-X spray in liner, 4.10's with limited slip, Diablosport Predator, K&N Filter, Mufflex/Magnaflow 24" muffler--best 1/4 mile 14.200 @ 95.76 mph (with 4.10's and no tuner)---Modding is far from complete!
