Old 11-24-2009, 11:15 AM
jgorilla's Avatar
jgorilla jgorilla is offline
Vehicle: 1995 ram 1500 2007 charger sxt
Color: red, grey
Rep:29
jgorilla is on a distinguished road
Default Remove my headliner
i have a 95 ram 1500 reg cab pu and i am wanting to remove the headliner. besides taking off the dome light, what else holds it in place (plastic clips, glue, ect.?)
same fight different round
Old 11-24-2009, 01:44 PM
jjhwick119's Avatar
jjhwick119 jjhwick119 is offline
Vehicle: 2004 Dodge Ram Reg cab
Rep:97
jjhwick119 will become famous soon enough
anything on the cieling. visor, oh sh*t handles, my ram has little hangers towards the back with screws in em.
pretty much anything mounted on your headliner needs to be removed
04 Dodge Ram 1500 SLT 2WD. De-Badged
Regular Cab, Black. drop shackles in rear to level
Old 11-24-2009, 02:07 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
NOTE: Headliner for Quad Cab model shown. Regular cab similar.
Remove the A-pillar trim panels (Refer to 23 - BODY/INTERIOR/A-PILLAR TRIM - REMOVAL).
Remove the upper B-pillar trim panels (Refer to 23 - BODY/INTERIOR/B-PILLAR UPPER TRIM - REMOVAL).
On Quad Cab models, remove the upper C-pillar trim panels (Refer to 23 - BODY/INTERIOR/C-PILLAR TRIM - REMOVAL).
Disconnect the wire harness connector (1) located at the left A-pillar from the headliner wire harness (2).
Disconnect the headliner wire harness connector (3) from the inside rear view mirror.
Remove the overhead console (Refer to 8 - ELECTRICAL/OVERHEAD CONSOLE - REMOVAL).
Remove the sun visors (4) (Refer to 23 - BODY/INTERIOR/SUN VISOR - REMOVAL).
Remove the sun visor supports (5) (Refer to 23 - BODY/INTERIOR/SUN VISOR SUPPORT - REMOVAL).
Remove the dome lamp (6) (Refer to 8 - ELECTRICAL/LAMPS/LIGHTING - INTERIOR/DOME LAMP - REMOVAL).
Remove the two coat hooks (7) (Refer to 23 - BODY/INTERIOR/COAT HOOK - REMOVAL).
Lower the rear of the headliner (9) downward from the roof panel (10) and disconnect the headliner wire harness connector (8) from the center high mounted stop lamp.
Lower the front of the headliner downward and remove the headliner through the passenger door opening.
