Old 11-25-2009, 12:29 AM
pantera101188666 pantera101188666 is offline
pantera101188666 is on a distinguished road
Thumbs down 96 dodge wiring problem
ok i am new to this forum and new to rams. sirst let me intruduce myself and my truck. lol. i used to hav 2 dodge dakotas but they were 2 wheel drive and only 3.9s. i decided i wanted a v8 4 wheel drive and couldnt find a dakota i liked so decided i give the ram a look. i saw the one i currently own and i love the thing to death. its a 5.9 v8 4 wheel drive ext cab slt laramie. now i do have some problems with it as would be expected seeing as were shes a retired construction truck all tho surprising in fairly good shap aside from paint. now the thing is every thing from the electric drivers side seat to the back of the truck dont want to work. the power seat i can live with but another thing that i noticed when i got it wich was wierd was that the back speakers also didnt get sound event when i put my aftermarket system in. so i had to run new wires for that. the main thing is when i got the truck the third brake light was out. i figured the bulb was dead so i orered a new led one from ebay. it looks cool i think. seeing as were i cant get it to work. you se i took out the old assembly and the bulb on it were fine. so my question is what could cause this and does any one no were the wires run so i can trace them. my power seat also dont work and neather does the dome light in the back. all that io can live with tho seeing as were the seat is ripped any way so im going to swithc it out with a regular seat once i find a manuall seat from a junker. also all the other lights in the rear work including the break lights blkinkers and reverse lights. just not the third break light. any help would be apreciated as i would like this fixed becuse cops around here like to pull people over for stupid crap like ur third brake light beeing out. thank you
Old 11-25-2009, 06:08 PM
Rep:1885
What year is the truck? Have you verified all the fuses are good? Do you have voltage and ground present at the 3rd lamp plug with the brake pedal depressed? If you do, check to see if you have voltage coming out of the stop lamp switch. If you have voltage there, you most likely have an open circuit. You can verify this with a continuity check and then proceed to hunt down the problem.
Last edited by RamTech; 11-25-2009 at 06:12 PM. Reason: My bad on the year. I missed that. Ill check my diagrams and see if they share a common connector that might have a problem.
Old 11-25-2009, 06:20 PM
Rep:1885
Ok, I found a connector that is shared by all the components you have that arent working. It's the C202 which is a black 12 pin connector. The view I have isn't a good one but it appears that it isn't too far from the interior fuse panel, perhaps in the kick panel or under the carpet on the drivers side.
Old 11-25-2009, 06:26 PM
ok thank you im going t try and see if its burnt or just disconnected. the cb2 fuse for my truck also isnt there but supposedly thats just for th seat and i cnat find were to get the fuse
Old 11-26-2009, 10:16 PM
ok so i found the problem. the wires for the back speakers the light the chair and pretty much every thing else in the back of the truck was burnt so im going to need to re wire it some how. thanks so much for your help tho
Old 11-26-2009, 10:21 PM
Rep:1885
Glad I could help.
Old 11-27-2009, 12:19 AM
hey one last quick question do you by any chance know what could ahve caused this? im just hoping it was from the wires getting wet for all these years becuse it wast the set that was under the carpet without the plastic guard. jsut so i know what to check when i re wire it. and thatnks again for your help i alsmost took the celling off becuse i figured the wires ran threw there.
Old 11-27-2009, 12:32 AM
Rep:1885
I'd check the fuses to the circuits first and make sure they're the right amp rating. Then check the associated wires for a short to ground.
Old 11-27-2009, 06:12 AM
ok thank you
Old 12-05-2009, 11:47 AM
ok i got every thing working and no fires yet and its been working for a week so i think im going to throw the carpet back in and put the truck back together, i asked my buddy whos a mechanic what he thinks what could of happend and we both figured from years of getting stepped on and wet becuse this was the area of wire that was not coverd that the rubber on the wires spilt causing a short. so thatnks again for your help and i will ry my best to answer other questions i can., as long as there not electrical lol
