Old 11-25-2009, 01:59 AM
white03ram1500's Avatar
white03ram1500 white03ram1500 is offline
Vehicle: 2003 Dodge Ram 1500
Trim Level: fabteck
Rep:42
white03ram1500 is on a distinguished road
Talking Help me I have a question??????
i want to lift the rear of my truck with the liftin blocks, i am goin to go with 2 inch block kit. My question is do i have to get longer rear shocks if i install these 2 inch blocks? thanks to anyone that can give me info to help with this question of mine.......
03 ram 1500 3 inch levelin lit w/ skyjacker shocks in the front
stock rear shocks
Old 11-25-2009, 03:54 AM
DODGE4x4's Avatar
DODGE4x4 DODGE4x4 is offline
Vehicle: 2006 Dodge Ram 2500 4x4
Trim Level: slt big horn
Color: tan
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Rep:82
DODGE4x4 will become famous soon enough
i wouldnt think you would need them with just 2", but it certainly wouldnt hurt to get them.
Old 11-28-2009, 06:51 PM
Trim Level: fabteck
Rep:42
thanks for the info, still lookin into the different block kits , leaf springs, leaf helper springs, and shackle kits........ just lookin for the easiest way to get a 1.5 inch lift or 2 inch lift, its got to be done in a weekend or less with no mess ups, this is my daily driver.......
Old 11-28-2009, 07:16 PM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
no, but it would probably be better being that you replaced the front.
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
Old 11-28-2009, 07:31 PM
You won't need to do them initially. The stockers should work just fine with that small of a lift.
Eventually, since they are running a couple of inches extended, they may wear out a bit faster than at stock height.
Old 11-29-2009, 09:19 PM
Trim Level: fabteck
Rep:42
Talking
i got front aftermarket shocks skyjacker, i want to do the back shocks too but i cant do it all at one time i got to save then buy the lift i chose, then if shocks are needed i wll save an buy. but i need to know if i use the lift with blocks, do i need longer shocks or can i ride the stock shocks till i can order the new matchin pair of shocks for the rear?
any help is good, not known sucks............... thanks for the info
Old 11-29-2009, 11:20 PM
ScatPak07's Avatar
Rep:970
Id like to see what the advice is cause I plan on doing the same thing
Old 11-30-2009, 09:34 PM
Ultimateride14's Avatar
Ultimateride14 Ultimateride14 is offline
Vehicle: 2007 Dodge Ram QC 4x4
Color: Inferno Red
Ultimateride14 is on a distinguished road
You should be fine running around for awhile on the factory shocks but remember the manufacturer puts on just long enough shocks for the factory suspension to cycle through its projected range. If you lift the truck the shocks will be extended to the amount that you lift. Say 2" so the shock is 2" higher than its correct working height. Maddog is exactly right on his comment. I say lift it now or later doesn't really matter on the shocks. If you like the way it rides i would go with a lift block since it shouldn't ride any rougher. If you use an add-a-leaf it will be a stiffer ride. Plus in my opinion lift blocks are much easier to put in especially if you have an impact. Let us know what you come up with.
Old 12-02-2009, 07:54 PM
Trim Level: fabteck
Rep:42
Smile
thanks for the info i will let you know how it goes, i am goin order the blocks and install them this weekend.
