Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - News Desk > Automotive Industry News and Dodge Press Releases
Automotive Industry News and Dodge Press Releases News regarding the Dodge Ram and other industry info. Post it here!
Old 11-26-2009, 01:16 PM
1970 Charger's Avatar
1970 Charger 1970 Charger is offline
Vehicle: 2009 Ram 1500 Crew Cab
Rep:28
1970 Charger is on a distinguished road
Default Chrysler transmissions to be a mixed bag
November 25th, 2009 by DaveAdmin
According to Allpar sources, while Chrysler
works on building eight-speed automatics, Fiat front-drive dual-clutch automatics, and its own six-speed transverse-engine automatic, it also seems to be planning to continue use of Mercedes WA580 five-speed automatics for rear wheel and All Wheel Drive applications. The upcoming Pentastar engine will, it appears, be used with both the Mercedes five-speed and the Chrysler six-speed automatic; the latter will also be coupled to a two-liter Fiat diesel. Other plans, including the destination for the eight-speed rear-drive transmission, are still uncertain.
Old 11-26-2009, 01:18 PM
MADDOG MADDOG is offline
Rep:22
whoa...that would be a tech's nightmare to keep up with all those combinations. However, I suspect they will be platform specific and not spread across the whole Fiat/Chrysler/Dodge line.
Old 11-26-2009, 03:51 PM
Rep:1877
Have you seen the variety of transfer cases Chrysler uses? They can't be any worse than that.
Old 11-28-2009, 03:44 PM
smarthead2006 smarthead2006 is offline
Vehicle: 2009 Dodge ram Crew cab
Rep:20
smarthead2006 is on a distinguished road
what trans was in the 04 dodge ram 2500 Hemi?
Old 11-28-2009, 05:35 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
The Mercedes transmission is pretty stout, too bad they wouldn't put it in the Rams.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 11-29-2009, 09:43 AM
Rep:28
I know, that is Dodges Achilles Heel. The transmissions that they use limit the mods that can be done to the trucks. The transmissions can't handle the HP, and are very sensitive to programming changes. If they used the Mercedes NAG1, all those problems would go away.
