Old 11-27-2009, 10:50 PM
Dontheramman's Avatar
Dontheramman Dontheramman is offline
Vehicle: 1996 Ram 1500 4x4
Color: Green
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
Dontheramman is on a distinguished road
Default Front wheel u joint
I have a 1996 ram1500, 4 wheel drive with a bad u joint on the drivers side front wheel what all do I have to do to replace is it a real pain in the butt or not to bad I turn wrench for everything else but have never changed one of these yet
thanks Don
Old 11-27-2009, 10:52 PM
Not hard to do at all. Might as well change both sides while you are at it. Are yours greasable? If not, look for some with grease zircs in them.
Old 11-27-2009, 10:55 PM
Yes it's gonna be a pain . Hardest part is getting the bearing/hub assembly off . We have a Chrysler tech on here . I will have to see if he has any tricks . I will let you know .
Old 11-27-2009, 10:56 PM
ah no...just get a puller and it's all good.
Old 11-27-2009, 11:02 PM
Doesn't look like hes on line right now . I'm sure he'll be on here later or tomorrow . I've done several . The hub just gets frozen in the spindle and takes alot to get it loose .
Old 11-27-2009, 11:48 PM
What do ya do when that happens?
Old 11-28-2009, 09:27 AM
Lot of banging with a maul or sledge hammer , slide hammer , heat , etc... Have done several bearings in 4x4's . Not a ten minute job .
Old 11-28-2009, 09:37 AM
MRRMX MRRMX is offline
Vehicle: 2007 Ram Quad cab 4x4
Color: grey
Rep:12
MRRMX is on a distinguished road
In areas where salt is used in large quanities.....Your right Tom..... We snap
the screw shaft on the puller OTC with Snap on screw shaft id say 1 out of 4
Wheel brearings....Never Seize does not help much on the seat area on the bearings.
Old 11-28-2009, 12:35 PM
ugh...snapped screw shafts on the puller? Had that happen to me once...pulling the crank pulley off of a 5.7L HEMI...sick feeling as that screw shaft was inside the snout of the pulley.
So they are really that bad always or is it just in salty, corrosive environments???
Old 11-28-2009, 01:21 PM
They are that bad all the time . Haven't done a easy one yet .
