Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 11-29-2009, 09:25 PM
iRockCrawler's Avatar
iRockCrawler iRockCrawler is offline
Vehicle: 2009 Dodge Ram 1500
Color: Mineral Gray Metallic
Rep:44
iRockCrawler is on a distinguished road
Post How-To: Installing Power Tailgate Lock
How to install Mopar Power Tailgate Lock Actuator (P/N 82211668-AB) on your 2009 Dodge RAM 1500
1. Disconnect Negative battery cable
2. Remove access cover on tailgate (8 T25 Torx).
3. Disconnect the actuator rods at the handle.
4. Remove the 2 nuts (5/16” socket) while holding the handle. (handle may fall out if you don’t hold it)
5. Remove actuator and Handle from tailgate.
6. Remove the 2 bolts (5/16” socket) holding the lock cylinder and remove cylinder
7. Drill 2 5/32” holes in the corners at location shown
8. Rivet the small bracket with the supplied rivets’ as shown.
9. Mount the power lock actuator to the supplied bracket with the supplied T20 Torx bolts.
10. Now for the tricky part. Put the lock cylinder in the handle but do not bolt it in. insert the power lock actuator rod into the bracket that was riveted on the lock actuator arm. Then insert then handle into the tail gate and then the power actuator/actuator . Note that the power lock actuator bracket will go over the lock cylinder and one of the studs in the handle.
11. Loosely put the 2 nuts that hold the handle to the actuator.
12. Install the 2 bolts that hold the lock cylinder .
13. Tighten the 2 nuts holding the handle and re-attach the actuator rods.
14. Plug the actuator (tailgate) harness into the actuator and clip it inside the tailgate. See instructions for the 2 locations as the flash is broken on my camera. LOL
15. Connect the jumper harness to the tailgate harness. Route the harness from the rear to the driver’s side fender and to the TIPM. I secured mine near the receiver so I have easy access to unplug it if I need to remove the tail gate. I routed the harness along the frame keeping it away from exhaust and suspension components. Tie-wrapped it pretty much the whole way to the brake lines.
Old 11-29-2009, 09:26 PM
Rep:44
16. Remove cover TIPM. Remove the B+ terminal nut (green arrow) from the TIPM and remove the B+ cable. Release the 5 tabs holding the TIPM to the battery tray, lift it out and turn upside down.
18. Remove the connector C5 (Letter E) pulling straight out. Then remove the black cover.
19. Cut the jumper harness to length leaving enough to go below the TIPM when its reinstalled.
20. Find the Tan/Light Blue (cavity 18) and Tan/Dark Blue (Cavity 22) wires and cut them about half way between the plug and where they enter the harness.
21. There are connectors supplied with the kit but I did not use them as I don’t have the proper crimp tool for the clips. I stripped all the wires, then Tinned all the wires. Place a 1.25” strip of shrink tube over one of the TN/LB wires & solder the TN/LB wires back together along with the Red wire from Jumper Harness. Place a 1.25” strip of shrink tube over one of the TN/DB wires & solder the TN/DB wires back together along with the Black wire from Jumper Harness. Instructions say White/Pink & Black/Dark Blue for the jumper harness but the wires in my kit were red & black.
22. Slide the shrink tube over the soldered parts and temporarily plug the C5 connector back in, install the B+ cable and nut and connect the negative battery cable. Lock/Unlock the vehicle to verify the wires are connected correctly. (if not, reverse the Red, black wires.
23. Disconnect negative battery cable, B+ nut and cable, disconnect the C5 plug again.. Heat the shrink tube until you see the glue coming out.
24. Reinstall the black cover for the C5 connector and plug it back it in.
25. Reinstall TIPM, B+ Cable/Nut, tailgate access cover and negative battery cable.
26. Remove tailgate key from Keychain and enjoy
Old 11-29-2009, 09:47 PM
Thanks for the how to install . Now the big question , Does it work ? Rep for that .
Old 11-29-2009, 10:43 PM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
So does the tailgate lock/unlock each time you lock/unlock the doors or did the kit come with a remote mod to add another button function to your remote?
Great write-up/documentation, by the way!
Old 11-30-2009, 08:03 AM
smartel's Avatar
smartel smartel is offline
Trim Level: Crew/Sport w/HEMI
Rep:47
smartel is on a distinguished road
Awesome How-to! Rep for that!
09 Crew Cab Sport, HEMI, Line-X spray in liner, 4.10's with limited slip, Diablosport Predator, K&N Filter, Mufflex/Magnaflow 24" muffler--best 1/4 mile 14.200 @ 95.76 mph (with 4.10's and no tuner)---Modding is far from complete!
Old 11-30-2009, 09:58 PM
Rep:44
It works great!! Basically it uses your normal remote and is wired to the lock/unlock wires for your doors. every time I lock/unlock with remote, it will lock/unlock.
I have mine set up to unlock all doors with one press. so it unlocks when I press unlock on the remote. Tomorrow I will change it to unlock the driver door on first press and the other doors on the second press and post if it unlock on the first or second press.
I will also try lock and unlock with the switch on the doors and see if it lock/unlock that way as well.
Old 11-30-2009, 10:00 PM
Cool feature . Didn't know that was available .
Old 12-01-2009, 09:54 AM
rjc799 rjc799 is offline
Vehicle: 2009 QC SPORT
Color: Sunburst Orange
Rep:121
rjc799 will become famous soon enoughrjc799 will become famous soon enough
What did it do? First or second?
2009 RAM QC Sport "Sunburst Orange"- Debadged; 4/5 drop; staggered 22s; speedstur tonneau; mufflex 14", limo tint
Painted: headlights (black with body color trim), interior, grill shell, ram head logos, windshield emblem, rim inserts & air filter cover
LOTS TO COME...
Old 12-01-2009, 01:27 PM
fuzzycali's Avatar
fuzzycali fuzzycali is offline
Color: Stone White
Rep:63
fuzzycali will become famous soon enough
Saw this on ebay/great accessory.great job
Have a dropped RAM? Want too? Join our group.
Lowered RAMZ Owners Club/Houston Area RAM Owners Club
At some point the mod list gets too long.
Old 12-01-2009, 06:40 PM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:432
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
That is a great write-up and awesome pictures. Thanks for the posting!
