Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 03-29-2010, 07:43 PM
DanoHB's Avatar
DanoHB DanoHB is offline
Vehicle: 2007 Dodge Ram 1500
Color: Electric Blue
Rep:32
DanoHB is on a distinguished road
Awesome. I need to do this too.
-----2007 Dodge Ram Sport 2WD "Electric Blue"-----
Old 05-06-2010, 02:34 PM
Raptor1000R's Avatar
Raptor1000R Raptor1000R is offline
Vehicle: 2010 Ram 1500 4x4 Sport Crew
Trim Level: Sport, buckets, RER
Color: bright white
Raptor1000R is on a distinguished road
FYI, I just priced it from the local dealer....$135 retail, $109 cost. Not too bad, considering it is Mopar! Great write up, Thanks!
2010,15004x4,Hemi,Sport,White,Crew,CAI,Predator,Li ne-X,Truxedo Lo Pro,2"level kit,PE Powergate
Old 08-14-2010, 01:44 PM
rlandon's Avatar
rlandon rlandon is offline
Vehicle: 2010 Dodge Ram Crew Cab 2WD
rlandon is on a distinguished road
Just finished my install of the kit, unfortunately with no success! Now none of the power door locks will work, nor will my front windows. I'm thinking it has to be a relay related to the RKE, since the RKE will power down the front windows if you hold down the unlock button. Not quite sure why it won't work. I followed the instructions here and reviewed the docs with the kit. I checked the connection against an DVM and get continuity from plug terminal to wire.
Unless I have a bad wire in the loom of the kit?? Dunno. Open to suggestions. I'm headed over to Dodge now, although service is closed for today and chat with the salesman being this is a brand new 2010 Laramie.
EDIT: I don't consider myself a noob here, being this is my 4th Ram and swapped over from the NitroForumz.
Previous Rams: 1954 C1-B6 Rodded, 1976 D100, 1994 RC, 1998 Supercharged EC, 2003 QC R/T Custom.
Old 08-16-2010, 08:52 PM
rlandon's Avatar
UPDATE: Dealership said the module is blown, which one they did not say, but part is ordered and now without a truck for two days. Did get a loaner via the warranty. In the meantime, my painted bug guard and Bilsteins arrived today. Now if I only had the truck to put them on.
Old 09-05-2010, 06:06 AM
dksram's Avatar
dksram dksram is offline
Vehicle: 2007 Dodge Ram 1500 Quad Cab
Rep:27
dksram is on a distinguished road
Wonder if someone did this on a 2007 ?
Old 09-19-2010, 10:00 AM
Sigi's Avatar
Sigi Sigi is offline
Vehicle: 2009 Dodge Ram
Trim Level: Laramie 4X4
Color: Austin Tan Pearl Coat
Sigi is on a distinguished road
Originally Posted by iRockCrawler View Post
16. Remove cover TIPM. Remove the B+ terminal nut (green arrow) from the TIPM and remove the B+ cable. Release the 5 tabs holding the TIPM to the battery tray, lift it out and turn upside down.
18. Remove the connector C5 (Letter E) pulling straight out. Then remove the black cover.
19. Cut the jumper harness to length leaving enough to go below the TIPM when its reinstalled.
20. Find the Tan/Light Blue (cavity 18) and Tan/Dark Blue (Cavity 22) wires and cut them about half way between the plug and where they enter the harness.
21. There are connectors supplied with the kit but I did not use them as I don’t have the proper crimp tool for the clips. I stripped all the wires, then Tinned all the wires. Place a 1.25” strip of shrink tube over one of the TN/LB wires & solder the TN/LB wires back together along with the Red wire from Jumper Harness. Place a 1.25” strip of shrink tube over one of the TN/DB wires & solder the TN/DB wires back together along with the Black wire from Jumper Harness. Instructions say White/Pink & Black/Dark Blue for the jumper harness but the wires in my kit were red & black.
22. Slide the shrink tube over the soldered parts and temporarily plug the C5 connector back in, install the B+ cable and nut and connect the negative battery cable. Lock/Unlock the vehicle to verify the wires are connected correctly. (if not, reverse the Red, black wires.
23. Disconnect negative battery cable, B+ nut and cable, disconnect the C5 plug again.. Heat the shrink tube until you see the glue coming out.
24. Reinstall the black cover for the C5 connector and plug it back it in.
25. Reinstall TIPM, B+ Cable/Nut, tailgate access cover and negative battery cable.
26. Remove tailgate key from Keychain and enjoy
Installed my automatic tailgate lock today, following your instructions. The heads up regarding colour coating of the wire really helped.
Thanks for the excellant step by step instructions. Works like a charm and yes, if you set your truck for 1 click for driver door and second for rest of doors, it works withe the rest of the doors. Set mine back to all doors at ones as far as unlocking is concerned.
Well worth the expense. Bought mine in the US, much cheaper than Canada.
Old 10-02-2010, 02:02 AM
grumpez grumpez is offline
Trim Level: R/T
Rep:61
grumpez will become famous soon enough
Thanks iRockCrawler, your info was invaluable for my install today. I sure appreciate it as your photos and instructions were so much better then the ones supplied with the part. Thanks again, great job!!!
Old 10-03-2010, 07:58 PM
RainmanX RainmanX is offline
Vehicle: 2010 Dodge Ram 1500 Crew Cab
Color: Inferno Red
Rep:19
RainmanX is on a distinguished road
I just did this today. A lot of work, especially for a bigger guy crawling around under routing the wires along the brake lines.
But it's cool, and one less key on my ring!
Old 10-08-2010, 03:12 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
Default nice
I was hoping to see some pics of where the actual lock goes on the tailgate, does anyone have pics of that?
thanks
Old 10-20-2010, 01:56 AM
mph300's Avatar
mph300 mph300 is offline
Vehicle: 2010 Laramie Crew 4x4
Color: Mineral Gray Metallic/Light Graystone Pearl Coat
Rep:41
mph300 is on a distinguished road
Default Two hours to titty tailgate
+1
I found the part, install instructions and pics all in one place!
AWESOME!
Works GREAT!
Mike
Got CH3NO2?
