Old 11-30-2009, 07:29 PM
ScatPak07's Avatar
Rep:970
Default Taking the leap
Hey guys I'm finaly taking the steps on raising my truck haha. I have a question I wanted to do the leveling kit for the front end. This raises the front 2". Now, I want to throw on a set of bigger tires what size would fit with only a leveling kit installed? Please say 34" haha
Any help would be appreciated since I wanna order my tires tomorrow hopefuly if things go well.
Old 11-30-2009, 07:46 PM
I have a 2" level on my '01 Ram and have 35's on it . But your a different body style .
Old 11-30-2009, 07:52 PM
ScatPak07's Avatar
Rep:970
Yep I want to fit a 35' tire on there. I'm hoping it will be able to. I looked some said 35 and others said 33 so I don't know what to believe haha
Old 11-30-2009, 08:29 PM
Ultimateride14's Avatar
Ultimateride14 Ultimateride14 is offline
Vehicle: 2007 Dodge Ram QC 4x4
Color: Inferno Red
Ultimateride14 is on a distinguished road
35's Should fit but if i recall you need to get a 1/4" spacer for the front wheels because they rubs. I know someone else can back me up on this.
Well i should correct myself if your running the factory wheels you need the spacers. Otherwise an aftermarket rim should work just fine. I'm thinking its 4 and 5/8" Backspacing but again someone needs to back me up on this since i don't remember very well.
Old 11-30-2009, 09:09 PM
ScatPak07's Avatar
Rep:970
I will definatley keep that in mind when making all adjustments. Thanks alot
Old 11-30-2009, 10:55 PM
DODGE4x4's Avatar
DODGE4x4 DODGE4x4 is offline
Vehicle: 2006 Dodge Ram 2500 4x4
Trim Level: slt big horn
Color: tan
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Rep:82
DODGE4x4 will become famous soon enough
i also read on another forum if running stock wheels youll need the 1/4" spacer. jus my .02
Old 11-30-2009, 11:13 PM
If your stock wheels are 4.5", you'll need to push them out a bit to fit 35's but you better work with a tire shop to get the right dimension. I'm with DODGE4X4. You'll need at least 1/4" to keep from rubbing on the inside.
