Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 12-02-2009, 07:55 AM
hemiram04 hemiram04 is offline
Vehicle: 2004 Quad cab 4x4
Color: deep molten red and silver
Rep:16
hemiram04 is on a distinguished road
Default Brake Caliper
Looking for input on front brake calipers. Got one sticking and they sell reman w and w/out mounting bracket . Just wondering which way was easier .
K&N c.a.i. , JET Perf module stage 1 , projector headlights and fog lights w/6k HIDs
Old 12-02-2009, 09:08 AM
Resident Technician
Rep:1915
Unless you need the bracket (ie wear, damage), there's no reason to get it.
Old 12-02-2009, 04:58 PM
Rep:16
Thanx appreciate it , dont want to waste $$ that could go to next project!!
Old 12-02-2009, 05:28 PM
Doing just one or both of them ? I would recommend both .
Old 12-02-2009, 05:45 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
Question
with that. If ones goin now it more than likely the other is just behind it. As for the mounting brakets. Are they easy to get off? if they are i wouldnt waste my money. I havent had to do mine as of yet.Great i just jinxedmyself
Old 12-02-2009, 08:54 PM
Resident Technician
Rep:1915
Yeah, they're easy enough to take off and you have to remove them to machine the rotors on a bench lathe.
Old 12-07-2009, 04:50 PM
CowTownRam CowTownRam is offline
CowTownRam is on a distinguished road
you should always replace calipers in pairs. They are really not all that expensive and worth it since you will be bleeding the brakes anyhow.
Old 12-10-2009, 05:11 PM
Rep:16
Well did em this weekend both sides . The only issue was a wrong caliper in the right box brake line bolt no fit ,two stores later to get the right one. Put on drilled and slotted rotors , tried the backs coulndt get em off lots of corrosion sprayed em ,try again another day.
Old 12-10-2009, 07:40 PM
Diesel fan Diesel fan is offline
Vehicle: 2003 dodge 2500hd
Color: gray
Diesel fan is on a distinguished road
Before you go to the expense of rpl the cailper chk to make sure it's not just the slider pins. I found this problem on my 03 the fix I did was to remove the slider and twist out the rubber boot. I then took some emery cloth and clnd the rust build up.I then bought some cailper slider grease and lubed both the boot and the pins this fixed my truck but if yours are both free then it is the caliper
Old 12-11-2009, 06:11 AM
Rep:16
Thanx didnt think of that , actually not sure if this was the problem but the caliper was placed over a mashed pad guide so it wasn't on straight. FYI got new calipers at advanced auto the internet price was 41.00 the in store price was 74 or 75 , they had to do a price match , got em for 41.
