Old 12-02-2009, 08:52 AM
bigrammer's Avatar
bigrammer bigrammer is offline
Vehicle: 2000 Dodge Ram
Color: Blue
Rep:27
bigrammer is on a distinguished road
Default 15 inch Wheel
Hey guys,
Just found out why my 15 inch rims will not be able to fit on my 2000 ram 1500.
Ends up my truck was the first year they went to a dual piston caliper. This makes the calipers even bigger. The backspacing on the wheels are 3.75". So i guess my question is, is there anyone who has a dual piston caliper set up for the 2nd generation running 15 inch wheels. If so could i get specs on your wheels?
Thanks for any help!!!!!!
Old 12-04-2009, 11:18 PM
bigrammer's Avatar
Color: Blue
Rep:27
Bump!!!!!!
Old 12-04-2009, 11:49 PM
Here's some wheel specs for ya!
1994-1999 1500 2WD/4WD Aluminum Wheels
• Lug Pattern - 5 on 5.5", 1/2" bolt
• Rim Size - 16x7.0"
• Offset - +13.97mm
• Backspace - 5"
• Max Tire Size -
• 15x8.0 rims with 3.5" backspace will fit, but they stick out of the wheel wells.
Torque Spec
• 80-110 ft lbs (108-150 Nm) on 5 stud wheels
2000-2003 1500 2WD/4WD 17" Steel Wheels (Chrome or painted)
• Lug Pattern: 5 on 5 1/2
• Rim Size: 17x7"
• Fits 94 and up 1500 trucks
2000-2003 1500 2WD/4WD 17" Aluminum Wheels:
• Weight: 23.5 pounds
• Rim Size: 17x8"
• Actual width edge to edge: 9 1/16"
• Backspacing: 5 9/16".
• The space from the outside edge to the mounting surface (against the rotor) is 3 1/2".
• offset calculate: 1 1/32"
Old 12-05-2009, 12:06 AM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
my buddy has a 2001 with 15" wheels,i think he shaved his calipers
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
Old 12-05-2009, 08:36 AM
Ramrob Ramrob is offline
Vehicle: 1999 Dodge Ram 1500 5.9L
Rep:75
Ramrob will become famous soon enough
True... When I was looking for 35's there was a set from a Dodge on 16's. My 03' has about a pinky finger gap between the inside of the 17's. I was talking to a local shop that installs lifts and stuff and he said he has personally shaved 5-10 Gen 3 Rams so they could run 16's.
