Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 04-25-2011, 12:46 PM
ramoreno's Avatar
ramoreno ramoreno is offline
Vehicle: 2002 Dodge Ram
ramoreno is on a distinguished road
i have the same problem, is fixed when i put water in the radiator. but i think is something else. because my temperature never get to the midle of the gauge, someone can helpme
Old 09-15-2011, 04:25 PM
rambob's Avatar
rambob rambob is offline
Vehicle: 2001 Dodge Ram
Rep:31
rambob is on a distinguished road
bump to the top
I have the same sound at start up and water on the pas side floor when I using the a/c.
PO said he replaced the heater core.
some where said it may be air trapped in the coolant system. but what could the leak be from?
i may have to take the dash out
Well I woke up Sunday morning,
With no way to hold my head that didn't hurt.
Old 11-08-2011, 07:38 PM
camoman214 camoman214 is offline
Vehicle: None right now
camoman214 is on a distinguished road
My '99 Ram made that 'sloshing' water noise when I first got it. It was just low on coolant. The noise was the coolant/air passing through the heater core. I filled the radiator and overflow tank to correct levels and the noise went completely away.
My water pump leaks, so I'm constantly adding coolant to my system.
As for the A/C issue: I would agree that either the evaporator is icing over because the system is low on freon or because of the orifice tube.
Good luck.
