Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2009 Dodge Ram Forum
Old 12-02-2009, 10:14 PM
MisterOX2009's Avatar
MisterOX2009 MisterOX2009 is offline
Vehicle: 09 Ram Crew Cab
Color: Inferno Red
Rep:47
MisterOX2009 is on a distinguished road
Send a message via AIM to MisterOX2009 Send a message via Yahoo to MisterOX2009
Default Disabling Seatbelt Chime
OK so I've read several places on the method, but nothing seems to work. Anyone have any luck disabling the seat-belt chime in the 2009 Ram?
Old 12-02-2009, 10:20 PM
iRockCrawler's Avatar
iRockCrawler iRockCrawler is offline
Vehicle: 2009 Dodge Ram 1500
Color: Mineral Gray Metallic
Rep:44
iRockCrawler is on a distinguished road
I just always wear my seat belt so have never felt the need to disable it
Old 12-02-2009, 10:35 PM
nt6977's Avatar
nt6977 nt6977 is offline
Vehicle: 2013 1500 Laramie Crew Cab 4X4
Rep:25
nt6977 is on a distinguished road
Click it or ticket...
nt6977
Old 12-02-2009, 10:38 PM
Airdog's Avatar
Airdog Airdog is offline
Trim Level: Sport 4x4
Color: Detonator Yellow
Rep:37
Airdog is on a distinguished road
Same here, it just makes sense plus I feel it sets a good example for my 3 kids.
It stops after a short period of time (96 secs) if you really insist on not wearing it.
I'm sure you've already seen this below.
From the Owners Manual
NOTE: The following steps must occur within the first
60 seconds of the ignition switch being turned to the ON
or START position. Chrysler LLC does not recommend
deactivating the BeltAlert.
1. With all doors closed and the ignition switch in any
position except ON or START, buckle the driver’s seat
belt.
2. Turn the ignition switch to the ON position and wait
for the Seat Belt Warning Light to turn off.
3. Within 60 seconds of starting the vehicle, unbuckle
and then re-buckle the driver’s seat belt at least three
times within 10 seconds, ending with the seat belt
buckled.
4. Turn off the engine. A single chime will sound to
signify that you have successfully completed the
programming.
BeltAlert can be reactivated by repeating this procedure.
NOTE: Although BeltAlert has been deactivated, the
Seat Belt Reminder Light will continue to illuminate
while the driver’s seat belt remains unbuckled.
~Airdog .
Old 12-02-2009, 10:42 PM
Rep:44
Yep.. here the fine is $60 to $500 and 2 points off your license.. quite often I see officers on the side of the road just checking for seat belts. not worth it IMO
Old 12-02-2009, 10:43 PM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:435
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
While I don't condone not wearing your seatbelt, i've seen people who click their seatbelts and then sit in the seat. I know you're an adult so I won't give you any speeches, BUT I have seen many people severely injured, ejected, and even killed because they didn't wear a seatbelt. Your choice.
Old 12-02-2009, 10:59 PM
First time your involved in a accident and Mr Airbag gets ahold of ya , you'll wish you were wearing your belt . Airbag deployed on a friend of mine in a accident . Wasn't wearing his seatbelt . Broke his neck and killed him . I can understand if you want that annoying chime done away with .
Old 12-02-2009, 11:44 PM
Color: Inferno Red
Rep:47
I'm not saying that I want to ride around w/o a seat-belt on. But when driving at extreme slow speeds (around the yard at work) or other places that I need to jump in and out of the truck, I'd like to not have that chime ringing in my ear constantly.
Old 12-02-2009, 11:56 PM
Rep:3322
This would be the same reason I'd do it. Plus, if you wanted to put in a 4- or 5-point harness this would remove the annoying chime.
Old 12-03-2009, 02:31 AM
jkulysses jkulysses is offline
Vehicle: 2007 Ram Quad Cab
Trim Level: 2500 4x4 HEMI
Rep:68
jkulysses will become famous soon enough
I need to do this to mine because i'm in and out of my truck all the time all on private property and the chime is getting old. Also I need to figure out how to make it not honk loud as hell when I lock the doors that also gets old.
