Old 12-03-2009, 08:24 PM
971500's Avatar
971500 971500 is offline
Vehicle: 1997 Dodge Ram 1500 4x4
Trim Level: Basic
Color: Emerald Green Pearl
Rep:16
971500 is on a distinguished road
Send a message via AIM to 971500
Default Motor wrap
hey all i have a 97 1500 with a 5.2L. The motor wraps when 1st start up then goes away but when I drive i can hear it through different rpm bands. I tried lucas oil add I also tried marrvel mystery oil. I dont know if its a lifter or rocker arm make the noise. Any advice would be awesome thanks
Old 12-03-2009, 08:40 PM
Rep:1885
If it's a rapping noise, I'd say piston slap or a bearing noise. Lifters and rockers are mroe likely to give you a tapping noise.
Old 12-03-2009, 08:42 PM
971500's Avatar
Trim Level: Basic
Rep:16
I was affaird of that...A need egine is like 1300 then to have it installed...this truck is going to be the death of me lol
Old 12-03-2009, 09:26 PM
971500's Avatar
Trim Level: Basic
Rep:16
should i stay with the 318 or should i go for the 360...My truck has a manual trans and no a/c would i need a computer for the 360 if i go that way
Old 12-03-2009, 09:45 PM
Rep:1885
If I'm not mistaken, the PCM is the same and would only require reflashing with the 5.9 software.
Old 12-03-2009, 10:36 PM
I've done the swap between a 5.2 and a 5.9 and never had a problem . Just make sure you change your torque convertor . 5.9 is externally balanced .
Old 12-04-2009, 09:00 PM
971500's Avatar
Trim Level: Basic
Rep:16
would i have to change the clutch and flywheel for the 5.9L i dont have an auto i have a manual trans
Old 12-04-2009, 11:15 PM
Flywheel , yes . Not sure about the clutch . ? I'll see what I can find out tomorrow .
Old 12-05-2009, 08:41 PM
971500's Avatar
Trim Level: Basic
Rep:16
sweet thanks for all the help
