Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Old 08-20-2013, 01:16 AM
bam2880's Avatar
bam2880 bam2880 is offline
Vehicle: 2013 dodge ram
bam2880 is on a distinguished road
Default Using oil?
I have a 13 ram 1500 with hemi and 8 speed with 550 miles and I checked the oil and is about half way down on the safe mark on the dipstick
Old 08-20-2013, 01:22 AM
JOlaskowitz JOlaskowitz is offline
Vehicle: 2013 Ram
Trim Level: Laramie crew cab
Color: Deep Cherry Red
JOlaskowitz is on a distinguished road
I have the same thing, drove 4200 miles, did not use a drop
Old 08-20-2013, 01:35 AM
bam2880's Avatar
When do you check your oil? When it's cold or when it's hot?
Old 08-20-2013, 01:37 AM
bam2880's Avatar
Also how did you break in your motor?
Old 08-20-2013, 04:03 AM
TinMan68 TinMan68 is offline
Vehicle: 2013 Dodge Ram 1500 Express
Trim Level: Express Quad Cab
Rep:45
TinMan68 is on a distinguished road
I have noticed you have to leave the hemi sit for a while till all the oil flows back to the crank case or you will get a false low reading. Its better if it sits over night to get a true reading.
2013 Dodge Ram 1500 Express Quad Cab 5.7L Hemi With 6 Speed Automatic And 3:55 LSD Gears and 20 Inch Rubber
2002 A6 3.0L 30V Quattro Avant Auto
2003 Nissan 350Z Enthusiast Model 6 Speed Manual
Old 08-20-2013, 06:08 AM
ValleyRacer ValleyRacer is offline
Vehicle: 2013 Ram RT
Trim Level: RT
Color: Steel Blue Metallic
Rep:136
ValleyRacer will become famous soon enoughValleyRacer will become famous soon enough
Default Nothing to fret over
You don't have to worry. If, as other replies in the thread mentioned, you have to remember to "double wipe" or double-dip the oil dipstick sometimes to get an accurate reading.
The oil will stay in the neck-tube of the oil dipstick housing and give inaccurate readings.
A double wipe or double dip will de-clog the residual oil.
If, though, you noticed a little oil consumption during engine newness, no worries - just the metal parts seating and a little factory fill oil blew-off.
Top if off and monitor the oil blow off. Good to see you checked your factory fill oil and observing such stuff.
Switch it over to synthetic by 2000 miles.
Old 08-20-2013, 10:19 AM
Venomouslou's Avatar
Venomouslou Venomouslou is offline
Vehicle: 2013 RAM 1500
Color: BLACK
Venomouslou is on a distinguished road
I changed my oil at 1500 miles. Let it sit for a few hours. Then just put something to put the oil in and just took the drain plug out. The oil filter makes a mess, just letting you know.
2013 Black RCSB 2WD 1500 EXPRESS
Old 08-20-2013, 05:34 PM
Color: green
Rep:643
is this the first time you checked it? was it full from the factory? your info says 4.7 engine, is that right?
Old 08-20-2013, 05:39 PM
bam2880's Avatar
No I just got a 13 hemi ram
Old 08-21-2013, 03:16 AM
Trim Level: RT
Rep:136
Default corrective action?
Did you top off the oil?
