Help from my cold weather friends! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-05-2009, 06:03 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
Default Help from my cold weather friends!
Today Blue voiced her displeasure at being in cold weather! I was over at my storage unit visiting my stuff. Wasn't there but 10 minutes. Was listening to the radio while I rummaged through boxes. It is sunny and 44 her right now. Found what I was looking for, got into Blue to get my lock for the unit and turned the key to start her up while I locked up. Got the familar click click of the dead battery. Called my dad, pulled my jumper cables out and awaited rescue.
Have the battery on a charger right now. So now here come my city girl questions:
Not a good idea to listen to the radio while the engine is off during cold weather?
Possibility my battery (which is the stock one, original) is going kaput?
Tips and pointers to educate me on vehicles and cold weather?
This is all new to me, have no clue and this is my go to place for advice!
Thanks!
Old 12-05-2009, 06:54 PM
Dann's Avatar
Dann Dann is offline
Vehicle: 1998 Dodge Ram
Trim Level: SLT sport
Color: red
Rep:183
Dann has a spectacular aura aboutDann has a spectacular aura about
first off this happens to us all.
Replace you battery, the battery inside has metal plates these are surrounded by deironised water, what happens when they get old the cold then buckels the plates thus not letting the battery hold its charge, or charge up fully again, pretty much the battery is busted. Now if you are going to get a new battery try and get a dry cell battery, this means the cold should never affect it again.
1 more thing if you are going to listen to radio with truck off, then start the truck every hour leave to run for 5 mins and switch off just to top up the battery, BUT if you have sub and amps then never have the sound on with vehicle off, as this will ruin the amps and battery in minutes.
hope this helps
Dann
Old 12-05-2009, 07:31 PM
Your battery probably has given up with all the abuse you've heaped on it...LOL
Before you replace it, take it to an AutoZone or similar parts store and get it tested.
Old 12-05-2009, 07:42 PM
Vehicle: Blue
Rep:3934
I do have two amps and a sub that automatically come on when the face plate is inserted. During the summer it was never a problem to listen while I looked through my stuff at the storage unit.
Should I get a heavy duty battery? One that will accommodate the stereo stuff as well?
Old 12-05-2009, 08:17 PM
Resident Technician
Rep:1915
Remember, you get what you pay for. This is especially true with batteries. I'm a fan of Interstate myself.
Old 12-05-2009, 08:23 PM
Vehicle: Blue
Rep:3934
I forgot to mention, the last few mornings it has been in the teens. When I have gone to start her up she rolls over once before she fired up. Does that mean anything to you??
Some of my audio friends said to get the yellow (?) top battery. I just want one that will start my girl up and not die!
Old 12-05-2009, 08:55 PM
Think it's time to retire Blue . It's seen better days . Time to cut it loose and by a Ram !
Old 12-05-2009, 08:57 PM
Vehicle: Blue
Rep:3934
I so wish!! Already got the color picked out and I want a 4x4!!
Old 12-05-2009, 08:59 PM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
get a optima!!!!!!!
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
Old 12-05-2009, 09:08 PM
Vehicle: Blue
Rep:3934
Any particular model?
