Old 12-05-2009, 09:43 PM
Uncle Buck's Avatar
Uncle Buck Uncle Buck is offline
Vehicle: 2010 RAM 1500
Trim Level: SLT 4X4
Color: Brilliant Black Crystal Pearl.
Rep:16
Uncle Buck is on a distinguished road
Default What transfer case is in my 2010 5.7L SLT 4X4 ?
Probably a dumb question but I have no idea ....
Old 12-06-2009, 10:16 AM
Rep:1877
You have either the NV243 or the NV 246. There should be a small circular tag attached to the rear of the transfer case with the model number on it.
Old 12-06-2009, 08:00 PM
Uncle Buck's Avatar
Trim Level: SLT 4X4
Rep:16
Yep .... right there. 243 D w/ 272 ratio.
Thanks man.
Regards,
UB.
Old 12-06-2009, 08:08 PM
Uncle Buck's Avatar
Trim Level: SLT 4X4
Rep:16
Found this ....
Number of Speeds:
1 = High range only, 2 = High and Low
Strength:
1 (low) to 7 (high)
Type:
1 = Part time,
2 = AWD,
3 = Electronic shift,
5 = Torsen dif.,
6 = Computer controlled wet clutch,
7 = GeroDisc,
9 = Viscous coupling
Thus a 243 = High/Low Speed Transfer case with Medium strength and electronic shift.
