tonneaucovered.com
Old 12-06-2009, 12:32 PM
Jaycan Jaycan is offline
Jaycan is on a distinguished road
Default Best way to lower a 05-06 Ram 1500
I'm looking at buying an 05-06 Dodge Ram 1500 4x4 with 20 inch rims. The problem I have is that I need to park it in an underground parking garage with a 6'3" clearance. I want to temporarily lower the truck to fit as I will be moving and want to put it back to the stock height when I move.
Can anyone tell me the best way/kit to do this.
Thanks
Jason
Old 12-06-2009, 12:38 PM
How much do you need to lower it? Is it taller than 6'-3" now?
Do you have alternate parking available?
The real basic question here is how much do you need to lower it. That will dictate the method used.
Old 12-06-2009, 02:43 PM
I push the skinny pedal
Rep:3308
Agreed, how much do you need to drop it? that's the most important question, followed by is it a 2WD or a 4x4.
Kurtis
Old 12-06-2009, 03:49 PM
I'm thinking the easiest way will be to remove a leaf or two in the rear and either shorten the stock springs up front (a cold cut - don't heat them up with a torch!) or replace them with a shorter set for now.
The spring work up front will be the most labor intensive.
But what to do here depends on how low he needs to go.
And he did note it's a 4X4.
Old 12-06-2009, 06:15 PM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
on board compressor, deflate tires before you pull up, inflate when you leave.
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
Old 12-06-2009, 06:45 PM
Well, that's a great idea Greg as long as he doesn't need more than an inch or two clearance.
We'll just wait and see what he has to say about how much lower he has to be. I wonder if he's measured the truck height yet.
Old 12-06-2009, 11:25 PM
I haven't bought the truck yet. But I want a 4X4 with 20 inch wheels.
According to http://en.wikipedia.org/wiki/Dodge_Ram all 02-08's ranged from 75.7" (6'3") to 80.8 (6'73") assuming the tallest ones are the diesels, the truck would be around 6'5" so I would need to lower it at least 2 inches.
I have thought about using lowered spindles on the front. Not sure about the rear.
Also an option could be using lower profile tires.
Any quality opinions will be appreciated.
Jason
Old 12-06-2009, 11:56 PM
With a 20" wheel you could go to a 255 or 245 aspect tire but that would look very weird on a 4X4 truck. Plus, your handling would suffer to the point you'd hate driving it.
A drop spindle is a possibility if you can find one that works with the IFS and to drop the rear, you could remove some leafs from the rear springs.
So your maximum vertical clearance is 75" at the parking garage?
You might have to go with 17" wheels and a 265 aspect ratio tire. That would be an easier and cheaper solution.
When I lift my truck, I won't be able to go into the parking garage at work or pull into my garage but I'll live with it.
Old 12-07-2009, 12:46 AM
Yes
I really want the 20 inch rims and a 4X4 and like the height but there is no where else I could park it.
So I either lower it somehow (which I'm trying to find the best way how) or move. Might just have to move. lol
Old 12-07-2009, 11:58 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
You could just ask these hotties to jump in the truck with you
