Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - News Desk > MOPAR NATION - Dodge Ram Club Regional Chapters! > Dodge Ram Forum CANADA
Old 01-05-2013, 12:06 AM
col's Avatar
col col is offline
Vehicle: 2012 Ram 3500 CCSB
Trim Level: Laramie Longhorn
Color: Black & Gold
Rep:92
col will become famous soon enough
Tower have been pretty good with me. My truck's Vin wasn't in the Recall for the Manifold bolts & Warping but they found it & fixed it when in for plugs & oil change...
2012 3500 Cummins Laramie Longhorn CCSB | 68 RFE | Black over Gold | RaceMe Pro Tuner | Flo pro 4" Stainless Steel Turbo Back Straight Exhaust | 5'' S/S Tip
Old 01-06-2013, 04:23 AM
CherryRam CherryRam is offline
Vehicle: 2012 Ram 1500
Rep:77
CherryRam will become famous soon enough
Hey LC did you get your TLC kit locally or order it online? I've been thinking of something like that for towing the horse trailer.
I get the shudder when I stop. It's like the truck does a quick shiver. I figured it was the MSD kicking in but I don't remember it doing it when I first bought it. But I can feel eco mode kick in and out while driving too. Unless this is a transmission issue... I'm over due for an oil change anyways, I should prbably ask them about it. My fuel milage has been out to lunch lately too. 17L/100 on the highway is starting to eat up the wallet a bit.
Old 01-06-2013, 11:29 AM
skid's Avatar
skid skid is offline
Vehicle: 2014 Dodge Ram 1500
Color: Maximum Steel
skid is on a distinguished road
My gas millage was that bad for a while after I took my truck in for a oil change. I thought they messed something up. Then I realized I had got the last two tanks of gas at Costco. Went somewhere else for gas and the mileage was back to normal.
Old 01-06-2013, 01:22 PM
col's Avatar
col col is offline
Color: Black & Gold
Rep:92
It's probebly the cold weather thats eating up your fuel .... Now it's getting a little warmer mine has settled down a lot... back to about 15 in the City..
Old 01-08-2013, 12:15 AM
LC Hauler's Avatar
LC Hauler LC Hauler is offline
Vehicle: 2014 Ram 2500 Laramie
Color: Bright Metalic Grey
Rep:72
LC Hauler will become famous soon enough
I ordered mine online direct from TLC.
My mileage has gone into the crapper, I've been holding at 19-21 consistently. I only use 2 gas stations..... I can get it down to 15 on he highway. I figured it might be the tires being a bit wider.
Old 01-08-2013, 11:40 AM
CanuckHRAM's Avatar
CanuckHRAM CanuckHRAM is offline
Vehicle: 2011 Ram Quad Cab 4 x 4
Trim Level: SLT Outdoorsman
Color: Deep Water Blue Pearl
CanuckHRAM is on a distinguished road
Originally Posted by RyanGroch View Post
amen on the tuner thing. figured it was a waste. i feel if u need more power and all that. buy a 1 ton diesel. simple.
i think the only thing worth purchasing it probably the air bags. for the leveling idea. i was thinking of the firestones. had them on an old truck and they were awesome.
im most definetly gonna do the swa to the blue when i change my trans fluid.thanks for the idea man!
i might invest in the hids too very soon. u have had no issues at all eh? had them on my old truck and they were so good. got alot of high beam flashes and middle fingers though haha.
Hey RyanGroch,
I pull a 26 Ft. Travel Trailer weighing in around 6500 Lbs. with my 2011 Outdoorsman. No problem towing - I try to keep between 100 to 105 kph on the highway for fuel mileage reasons. Had a 2003 Quad Cab Hemi previous to that. I put the Firestone Coil Rite Air Bags on the rear of my 2011 as it had pronounced sag right from day one - even with my weight distribution hitch. It works great now. The TLC system is also an awesome system if you can get a good deal on one. I might also invest in the HID's that LC Hauler sells as he seems to have had good luck with them and these trucks sure could use better headlights. You can aim them up and down but not side to side - figure that one out?
Raider Phantom Topper, K&N Drop-In Air Filter, Vent Visors, SmittyBilt Light Bar & PIAA Lights
Old 01-08-2013, 01:37 PM
2500hd's Avatar
2500hd 2500hd is offline
Vehicle: 2010 Ram 2500 HD
Color: Austin Tan
Rep:32
2500hd is on a distinguished road
Do you guys have any suggestions for reputable gear/differential shops in Southern Alberta? Looking to get some quotes, but not sure where to start.
Thanks
-Amp Research-Fuel Offroad-Nitto-Diablo-Rigid Industries-Craven-CJC Offroad-Carli-BT-
Old 01-08-2013, 03:16 PM
FrostKing's Avatar
FrostKing FrostKing is offline
Vehicle: 2003 Dodge Ram
Color: Graphite
Rep:23
FrostKing is on a distinguished road
Thanks
The shops that do the most are the 4x4 shops. I had mine done at Temple of Torque in Calgary, but the name has changed since then. Honestly, I was given a price of $700-800 at my local Dodge dealer in Cochrane for re-installing my original 3.55s and I don't think that's too bad.
2014 White Crew Sport 4x4 8-speed 3.92 gear
Sold: 2003 RCSB 2WD
6.4L Hemi - Turbocharged, Alcohol, Nitrous
Old 01-08-2013, 10:34 PM
Rep:77
Thanks
Try The Gear Centre in Calgary.
Old 01-09-2013, 04:49 PM
CanuckHRAM's Avatar
Thanks
I hate to send any negative comments out but I have heard nothing but bad reviews lately, mostly by automotive tradesman, of work done by Pat's Driveline in Calgary. I personally have a friend who had them check his driveshaft for balance and although they told him it was withinin Spec., they went ahead and tweaked it more anyways but did not ask his permission first. It was a highly detailed (painted) driveshaft from his Vintage Musclecar and when he picked the driveshaft up he nearly blew a gasket. There were deep gauges in the unit and they had repainted the entire thing with rattle can black - just looked horrible. He re-installed it on his car and the vibration he previously had was even worse.
Just thought others should know as this place might not be your best bet.
