Shifting into 4 wheel drive - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-09-2009, 12:36 PM
JOKER's Avatar
JOKER JOKER is offline
Vehicle: 00 Dodge Larime 1500 4x4
Rep:32
JOKER is on a distinguished road
Send a message via Yahoo to JOKER
Default Shifting into 4 wheel drive
crazy question how should I put my truck into 4wheel drive?
And also should it stay in 2 wheel or nuetral when not in use?
Old 12-09-2009, 12:46 PM
Resident Technician
Rep:1915
Need some info in your truck first, but if you keep the case in neutral, you won't go anywhere!
Old 12-09-2009, 12:54 PM
JOKER's Avatar
Rep:32
sorry bout that. It is a 00 dodge larime 1500 4x4.
Old 12-09-2009, 01:07 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
Hello. Iguess you have a automatic 4x4? You should have it in 2 wheel unless you need 4 low or high. If its in neutral you wont be able to go anywhere. What are you planning on doing. Your in florida? No snow there eh.
Old 12-09-2009, 01:11 PM
JOKER's Avatar
Rep:32
No, Snow. LOL. But plenty of sandy hills. just wandering cause the shifter looks like it is all the way up. Maybe in 4 high. So I wanted to know how to put back in 2 wheel. never had a 4 wheel drive before. Yes by the way it is an automatic.
Old 12-09-2009, 01:18 PM
bones64's Avatar
Rep:659
Question
Do you not have a shift indicater on the dash or were your 4x4 shifter is located. I cant remember if up all the way is 4 high or 2 wheel.
Old 12-09-2009, 01:41 PM
frezingbelow frezingbelow is offline
Vehicle: 2001 Dodge Ram 1500
Color: Black/Silver
Rep:135
frezingbelow will become famous soon enoughfrezingbelow will become famous soon enough
If you look at the shifter knob it shows you. top is 4 low then neutral then 2wd then 4 high at the bottom. As long as your not moving you can shift it.
As bones said you should have an indicator on your guage clusted that shows what your in.
Old 12-09-2009, 01:45 PM
bones64's Avatar
Rep:659
I thought so. BTW i ment the knob on the shifter sorry. Knob for a knob sometimes i is.
Old 12-09-2009, 03:06 PM
JBSPartans05's Avatar
JBSPartans05 JBSPartans05 is offline
Vehicle: 06' Dodge Ram 1500 4x4 HEMI
Trim Level: Big Horn Quad Cab
Rep:54
JBSPartans05 will become famous soon enough
I got a quation on this too when shifting in and out of 2WD and 4WD Lock
Is it normal to get a JUMP until its engaged???
And seems like the gas pedal is really jumping alot when hit at low speeds making it hard to park/pull out of spots
Joe East Lansing, Michigan
Dodge Ram 1500 Big Horn 4x4 5.7 L Hemi QWD!!
Old 12-09-2009, 03:11 PM
bones64's Avatar
Rep:659
Well i have had only a couple 4x4 both of them Dodge (of course). I never shifted while moving. I never felt comfee doin it. I just came to a stop and shifted it to were i needed it. Mind you with both trucks i hardly used the four wheel drive. This is why i have a 2 wheeler now. On occasion it does suck ...........like right now.snow,snow,and oh yah! snow.
