Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 12-09-2009, 10:48 PM
rnhansen rnhansen is offline
Vehicle: 2004 Dodge Ram
rnhansen is on a distinguished road
Default Shaking while braking
My truck shakes when braking at fast speeds. Its almost pulsating but not. I turn the rear rotors. still have the problem. Do I replace rotors or is this a common problem. One of the techs I work with said that some shortbed trucks just do that.
Old 12-09-2009, 11:01 PM
Can you feel the shaking in the steering wheel ? Have you tried resurfacing the front rotors ?
Old 12-09-2009, 11:18 PM
Resident Technician
Rep:1915
They aren't supposed to whether it's a short bed or not.
red041500 red041500 is offline
Vehicle: 2009 ram 1500 crew cab
Color: bright silver
Rep:22
red041500 is on a distinguished road
sounds most definatly like a warped rotor , id cut the fronts.
Old 12-09-2009, 11:20 PM
No, that's not normal. Besides the rotors, make sure your calipers are mounted tightly, your wheel bearings are in good shape and you don't have a loose wheel!
Old 12-10-2009, 07:59 AM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
Before you cut the rotors, make sure they are in spec. enough to do so(if they are not warped)...They may be worn down too much, and you have to replace them or they will be a waste of time a cut...If your steering wheel is shaking, it could be a balance issue(this would be costant though while driving), and could get extreme while your breaking...
Old 12-10-2009, 09:37 AM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
Yes sir i got to agree. I have a short box and never had any problem like this at all.Sounds like rotors, caliper. I have heard that your caliper can sometimes not engage all the way in and out. Not sure if this is the problem or not. Is there enough left on your rotors now that you turned them. If they are to thin they can warp easy with the heat and not work properly as well. Just my thoughts dont take them to the bank though. Im not a mechanic!
Old 12-10-2009, 10:55 AM
98RamSport's Avatar
98RamSport 98RamSport is offline
Vehicle: 1998 1500 Quad Cab
Color: White - Black Trim - Red Sport Decals
Rep:94
98RamSport will become famous soon enough
I dropped my truck off at the shop this morning for this same thing. Got a long trip coming up and don't have the extra time right now to do it myself. I thought it was the wheels, but they test drove it and said it was something in the brakes. They are checking it right now. I'll post up what they say when they call back. I know my problem might not be yours, but it might help.
Old 12-10-2009, 11:59 AM
98RamSport's Avatar
Rep:94
Damn service department! They called two hours ago and said they test drove my truck and would have to look at the brakes. I just called back and they said they haven't gotten to it yet and wouldn't be able to till after 2pm this afternoon. I dropped it off at 8:15 and they won't be able to tell me what's wrong till 2?????? I have to pick up a trailer at two today. Looks like this won't get fixed till after the move.
Old 12-10-2009, 05:47 PM
Thermool Thermool is offline
Thermool is on a distinguished road
i have an 2006 1500 mega cab with the HEMI that had the original front breaks done at 41,000 miles. i have the same issue too now but its coming from the rear. check your tire pressure, the recommended for me is 40 all the way around. but I run 50 instead, too wishy-washy @ 40. but as soon as I want to tow i change the rear to 70 and keep the front @ 50 and thats when I have the issue.
