Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 12-10-2009, 06:15 PM
Rep:1877
Originally Posted by Thermool View Post
i have an 2006 1500 mega cab with the HEMI that had the original front breaks done at 41,000 miles. i have the same issue too now but its coming from the rear. check your tire pressure, the recommended for me is 40 all the way around. but I run 50 instead, too wishy-washy @ 40. but as soon as I want to tow i change the rear to 70 and keep the front @ 50 and thats when I have the issue.
Are you getting your "recommended" pressures from the sidewall of your tires? Running pressures that high will cause a rough ride and will wear out the center of your tires prematurely.
Old 12-10-2009, 10:55 PM
bstrange99's Avatar
bstrange99 bstrange99 is offline
Vehicle: 97 ram 1500, club cab.
Trim Level: SLT Laramie
Color: Lt Montego Blue Metalic
Rep:23
bstrange99 is on a distinguished road
Once brake rotors get hot spots, turning them will do no good. As soon as those spots get hotter than the rest of the rotor, they swell up, causing a vibration during braking. You may need to replace the rotors.
Old 12-11-2009, 11:23 AM
Bobcat06's Avatar
Bobcat06 Bobcat06 is offline
Vehicle: 2002 Ram 1500 Quad Cab
Rep:91
Bobcat06 will become famous soon enough
Yeah, you should reconsider your tire pressure choices. That seems way too high. What do you mean at 40 psi your tires seem 'wishy-wahy'? I would consider lowering them instead of increasing them.
