Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
MOPAR DECALS
Old 12-11-2009, 09:25 AM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
Question Need advice
Hello everyone. Now that the cold is here i was courious to know what product would be the best for keeping my doors from freezing up. I heard silicone spray was good. Is it? anything else?
Old 12-11-2009, 11:59 AM
Bobcat06's Avatar
Bobcat06 Bobcat06 is offline
Vehicle: 2002 Ram 1500 Quad Cab
Rep:91
Bobcat06 will become famous soon enough
There is a de-icer spray you can get at most auto parts stores. You can use it to spray into your keyholes or door jams. Works pretty well at thawing out a small amount of ice fairly quickly. As far as preventative, I'm not sure, a garage??
Old 12-11-2009, 12:01 PM
For your locks, try some graphite powder. It won't freeze like other liquid based lubricants.
For inside the door jambs on your locks and strikers, the hood latch (underneath the hood) and for the tailgate lock striker, use white lithium grease.
Old 12-11-2009, 01:10 PM
bones64's Avatar
Rep:659
Sorry everyone. Im not talking about the locks. The actual door itself. You have the rubber?foam strip around the inside. Door is unlocked and you have to pull real hard sometimes to open it. Maybe you guys dont have this problem. Up here in Canada we get stuck doors often.
Old 12-11-2009, 02:45 PM
Bobcat06's Avatar
Rep:91
Well if it's the foam that's freezing i'd be real careful about yanking the door open, it could tear that foam. I'm not sure what you could put on it to work. I'd look into getting a remote starter for you truck, that way you could start it and let it warm up and then try and open the door.
Old 12-11-2009, 02:46 PM
MightyBlueRam's Avatar
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:435
I was trying to find a solution for you and on youtube. There's a bunch of "How to winterize a car" videos on there from ehow. Hope this helps and stay warm.
Old 12-11-2009, 04:49 PM
canuckboy's Avatar
canuckboy canuckboy is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: None
Engine: 1994-2001 239ci (3.9L) Magnum V6 175hp
Rep:114
canuckboy will become famous soon enoughcanuckboy will become famous soon enough
Spray WD-40 either on the door seals and wipe of excess with a shop rag... or spray it on the shop rag and wipe down the door seals.
Works pretttttty good for me so far
Old 12-11-2009, 07:16 PM
beermanjoe's Avatar
beermanjoe beermanjoe is offline
Vehicle: 2007 Ram
Rep:25
beermanjoe is on a distinguished road
Sprayed WD-40 in my garage door lock last night. Froze,couldn`t even get the key in it.
Old 12-11-2009, 10:43 PM
ScatPak07's Avatar
Rep:970
I've never had that problem but I'd like to know how to prevent it anyway
Old 12-12-2009, 06:10 PM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
Not a good idea. WD-40 is not meant for rubber. It'll deteriorate the rubber over a period of time. That's why many motorcyclists tell you never to use WD-40 on your chain. You can go to any parts store and look for a low temp silicone based lube that'll work on rubber and plastic. WD-40 is mainly for metal.
