Old 12-12-2009, 08:55 PM
yankeefan4ever yankeefan4ever is offline
Vehicle: 2002 Dodge Ram 1500 Quad Cab
yankeefan4ever is on a distinguished road
Default Getting heat on only passenger side
Turned my heat on the morning in my and there is hot air coming from only the passenger side vents (dash and floor). The vents on the driver side are blowing much cooler air. Also the defrost vents seemed to be blowing cooler air. My guess is that it's some valve or door behind the dash and not the heater core or thermostat since I am getting some hot air. Can anyone help me with this one?
Old 12-12-2009, 09:00 PM
Welcome to the forum.
What year/model is your truck? I suggest you re-visit your User CP and edit your details to add that info. It will help us help you.
I suspect the diverter valve in the HVAC module is stuck. Configurations of this system are a bit different from generation to generation of Ram so that's why it's important we know what year you have.
Attached is a set of instructions on how to get to that system from the FSM for the 2nd generation Ram.
In a moment I'll post up an exploded view drawing that may also be helpful.
File Type: doc HVAC Blend Door and Module Service.doc (506.5 KB, 195 views)
Old 12-12-2009, 09:01 PM
Here's the exploded view drawing.
Hope this info helps and good luck with your repair!
Old 12-13-2009, 12:47 PM
Default Thanks
Thanks for the info, I really appreciate it. Hopefully it's something I can do myself.
BTW, I have a 2002 Ram 1500 Quad Cab.
Old 12-13-2009, 12:49 PM
The info I attached is for the 2ND Generation Ram but the principle (and maybe the design) would be similar.
Glad to help. Keep us posted on how it goes!
Old 01-28-2010, 03:23 PM
djlahawk djlahawk is offline
Color: GOLD
djlahawk is on a distinguished road
did you problem ever get resolved? I am having the same problem
Old 01-30-2010, 06:12 AM
TRKNHEMI05 TRKNHEMI05 is offline
Vehicle: 2005 Ram 1500 Hemi 4x4
TRKNHEMI05 is on a distinguished road
Default Similar problem on 2005 Dodge Ram 1500
I had a similar problem on my 05' Ram, I can only get heat in the dash and upper window vents, none on the floor. I think its one of the air blend actuators on the vent system, there are three on the vent housing under the dash. I hope yours is fixed. See attached pics..(replacing the heater core is another story!) By the way, all the actuators have the same part number.
Old 09-18-2012, 09:44 PM
jlentz1988
I have an 02 ram 1500, and i have the same problems. Heat on passenger side and blows cold on driver side. please help!! when i switch temp from cold to hot i get a short burst of warm air out of the driver side for aprox 5 seconds then back to cold. any suggestions?
Old 09-26-2012, 11:27 PM
02quadcab 02quadcab is offline
Color: Gray/silver
02quadcab is on a distinguished road
I have not seen a solution yet to this problem, the air is warm on the passenger side, but cool on the drivers side. I replaced the heater core and the evaporator core last year.
Old 09-27-2012, 04:04 AM
Rep:2616
go to YOUTUBE
this is what you will see, i believe the 3 heatertreater videos cover most everything
there are others that may be just as good
http://www.youtube.com/results?searc...roubleshooting
