Old 12-12-2009, 11:22 PM
GeeJay GeeJay is offline
GeeJay is on a distinguished road
Default 2010 2500HD vs 3500HD
I have been waiting patiently (ok, not so patiently) for the poop on the 2010 Ram HDs and see it is finally on the Dodge website.
I am considering purchase to replace my 07 Sierra 2500HD 8.1L. I am fulltime RVer and looking at new 5W travel trailers GVWR 16K - 17K#.
I chose the Sierra 2500HD instead of 3500HD because everything except springs and tires is identical. I added 5K AirLifts and upgraded tires to 165s and, presto, everything the same as 3500HD except better ride solo.
I chose the Big Block because, with 4.10 gears, which were not available with the Duramax except in a 3500 DRW, the BB tow rating is actually higher. Also saved megabux.
However the time has come to get more tow capacity and I feel the Cummins is the class act in the small field. Now I have to determine if I can upfit a 2500 to the same chassis + rear axle & spring capacity ( not Dodge rating) as 3500.
Are the chassis the same? Are the axles the same?
Hope someone can help me with this one.
GeeJay
Old 12-12-2009, 11:40 PM
Rep:1877
Both trucks are available with the 10 1/2 AA (3.73, 4.10, 4.56), the 11 1/2 (3.73, 4.10), and the RBI 302 (4.10, 4.44, 4.88). The 3500 has a set of auxillary springs and spring bumpers that are not offered on the 2500. I'm not sure about the 2010 model 3500, but previous models were available in a SRW configuration. Also, I'm not sure if the frames are the same due to the different chassis designations and I have yet to see both trucks in our dealership.
