Old 12-13-2009, 03:36 PM
megacabmatt megacabmatt is offline
megacabmatt is on a distinguished road
Default 06' Mega Cab tire question
Hi guys,
I have an 06' Mega cab 1500 4x4, with stock 265x70xR17 tires and I am upgrading to 285x70xR17 Maxxis Buckshot Mudders and am concerned they wont fit on my rim and concerned about rubbing. The spec sheet for the tires say the rim width range is 8.5, not sure what the measurement for my stock rims are.
http://www.maxxis.com/AutomobileLigh...ot-Mudder.aspx
Any similar experiences or thoughts would be much appreciated. Thanks.
Old 12-13-2009, 03:46 PM
Rep:1845
I'm pretty sure your rims are 8" You can check yourself by taking a coathanger and using it as a caliper of sorts to measure the width of your rims at the bead while still on the truck. An 8" rim should measure out around 8 1/4 to 8 1/2".
Old 12-14-2009, 02:40 AM
ram2487's Avatar
ram2487 ram2487 is offline
Vehicle: 2011 Dodge Ram 2500 Mega Cab
Rep:37
ram2487 is on a distinguished road
they should fit fine with no problems at all. i had the stock wheels on my last 1500 and and went from 245/70/17 to 285/70/17 with no rubbing at all, and that was before i raised the front 2"
2011 2500 6.7l Mega Cab Laramie 4X4
Old 12-29-2009, 08:25 PM
Megacab07's Avatar
Megacab07 Megacab07 is offline
Vehicle: 2010 Ram 1500
Megacab07 is on a distinguished road
I have 275's on my '08 Mega and have had no problems. Plenty of room.
Old 12-29-2009, 09:14 PM
yotehtr yotehtr is offline
Vehicle: 08 Ram 1500
Trim Level: ST Reg Cab 4x4
Color: Metallic Gray
Rep:28
yotehtr is on a distinguished road
Default ...
I got 285s on steel 17x7 wheels with no problem. looks good and works great on and off road.
Old 12-30-2009, 02:47 AM
hemi05's Avatar
hemi05 hemi05 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:35
hemi05 is on a distinguished road
should fit just fine. You'll like the buckshots, just be sure and keep them rotated. I had a set on the last truck I had, if you don't keep an eye on them, they start to wear wrong and they will bounce you to death from about 15-40 mph. lol. but I guess that's every mud tire.
