Tuned up?! - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
Diesel Forums!
Dodge Caliber
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Place your Ad Here!
Old 12-29-2009, 01:35 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
good job brutha!! nuttin like the satisfaction of doin it yourself...I was almost the same way when i first got my Ram in 05..I knew how to do the simplest stuff like that...then I started readin through the forums and started tinkerin more an more...now, guys are comin over to have me 'tinker' on their trucks..... that's me in the engine bay of the red truck..
Old 12-29-2009, 01:39 AM
Rep:3347
Originally Posted by MrCantu View Post
Thanks, I'd need advice, well more like a walk through on changing the spark plugs...
Thanks buddy, what's the proper tool used to change the spark plugs on an 02 ram?
It's a special deep socket with a rubber insert so you don't snap the ceramic on the plug.
Old 12-29-2009, 04:49 AM
shorty 4x4 shorty 4x4 is offline
Vehicle: 1986 Dodge Power Ram 150
Trim Level: Custom
Color: Ugly Yellow right now
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
Rep:9
shorty 4x4 is an unknown quantity at this point
Yes sir I do feel very proud =)
You should know....1/2" or whatever...
Gap? any idea? Such a Virgin.
Sockets...
Read your manual...you do have one right?
Originally Posted by Incognito View Post
Good stuff man. You learn a lot from doing things on your own, and if you break things, which'll happen, then you keep on going and keep on fixing. Far better than paying someone else to do it. Invest in some good tools and keep logging onto the forum and asking questions.
"keep on going and keep on fixin'"...
Said well...
How about if I have had it with fix'. Just want to watch the work?
Listen Fred and Incog...
I have an old truck i'd like to see restored. On TV would be nice but. Not neccassary.
get my drift?
local pros ...all local and advertized.
Old 12-29-2009, 05:16 AM
chefred112's Avatar
Rep:656
wow shorty...good info you've provided...
chefred112's Avatar
Rep:656
Originally Posted by shorty 4x4 View Post
get my drift?
uh...no
Old 12-29-2009, 05:21 AM
chefred112's Avatar
Rep:656
Mr Cantu...can you tell us what motor you have in your 02? can't be a hemi cuz they dint start using them til 03+. So I think the motor choices are 3.7L, 4.7L or 5.9L...
Old 12-29-2009, 05:27 AM
chefred112's Avatar
Rep:656
uh..try 5/8th's with the rubber boot....most used for spark plug changes are 3/8" drive sockets an wratchet's seein as spark plugs are mostly tq'ed to 7lbs which doesn't require any drive bigger then 3/8th's... AND, we were all virgins at one time or another...
Old 12-30-2009, 01:56 AM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
You can pick up spark plug tool kits at your local hardware store, if not build your own kit with the following:
Spark Plug Sockets (5/8", 3/4", 13/16")
3/8" Drive Ratchet
4" Extension
6" Extension
3/8" Drive Universal Joint
Nose Picker*
* I don't know what these are normally called, but these are so handy to have around. Remerson knows what I'm talking about. It's a long, flexible tube around 80cm long with a prong at one end for you to pick up stuff from tight spaces you can't normally reach.
I don't have the slightest idea what you're talking about.
Old 01-01-2010, 05:41 AM
MrCantu's Avatar
MrCantu MrCantu is offline
Vehicle: 2002 Dodge Ram 1500
Rep:164
MrCantu has a spectacular aura aboutMrCantu has a spectacular aura about
it's an 02 so 4.7L Magnum
Old 01-01-2010, 05:44 AM
MrCantu's Avatar
Rep:164
My uncle said it's good to use one of those that have magnets so I won't drop the sprak plug...
I still haven't changed them, because of the holidays getting in the way but this weekend I plan to get it done!
filter, mrcantu, oil, spark plugs, tune up
