Old 12-13-2009, 10:06 PM
blazn189 blazn189 is offline
blazn189 is on a distinguished road
Default Torque converter questions...
ok here goes ... i have a 86 ram 4x4 318.. and a 86 ram 2wd 318 (using for parts)... my tranny went out it the 4x4 so i was gonna swap the 2wd trans in it for time being.... well pulled tranny and transfer case today and went to put in the 2wd tranny torque converter wasnt the same.... 2wd has more splines on input shaft.. my problem is that i didnt keep the torque converter from the 2wd.. what converter can i get to use the 2wd trans on the 4wd? will it even work? what are my options? need advice asap
Old 12-14-2009, 03:22 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Sounds like one is a 904 and the other is a 727. Here is some great info on identifying which is which:
Identifying and Exchanging Torqueflite Transmissions
Old 12-14-2009, 11:02 PM
See if this helps ya . I agree with Chithead , sounds like your installing a 904 . http://www.transmissioncenter.net/PanShapes.htm
