Old 12-13-2009, 09:48 PM
supercharged03hemi's Avatar
supercharged03hemi supercharged03hemi is offline
Vehicle: 2003 ram 1500
Color: graphite
Rep:35
supercharged03hemi is on a distinguished road
Send a message via Yahoo to supercharged03hemi
Default Predator Help
I have a Paxton supercharger that is programed to run a max of seven pounds of boost. If i put a Predator programmer in my truck, will that mess up the tune of my supercharger. And if it wont, will I have to get a custom tune or anything like that.
Old 12-13-2009, 09:56 PM
Get Bit's Avatar
Get Bit Get Bit is offline
Vehicle: 2004 Dodge Ram RC 4x4
Trim Level: SLT Sport
Rep:71
Get Bit will become famous soon enough
How is the system "programmed" to run only Xpsi of boost, since it is all based on the size of pulley that you're running? Or do you have a BOV that is set for X amount of boost?
I would think that adding a predator on top of things might step on your tune, if you've had a custom one done. But I am not sure what attributes the predator changes, versus if you had a tune done.
Old 12-13-2009, 10:25 PM
I'd strongly suggest you get a custom tune to load with the Predator.
It won't run very well with one of the stock tunes from that tool.
Old 12-13-2009, 11:35 PM
Color: graphite
Rep:35
There is a little box that gets plugged into a computer and they do something with it. Im not really sure how it works.
Old 12-13-2009, 11:43 PM
Get Bit's Avatar
Rep:71
Hmm, that is different.
Have you had your truck on the dyno or at the track?
Old 12-14-2009, 01:03 AM
Fast Willy's Avatar
Fast Willy Fast Willy is offline
Vehicle: 2008 Dodge Ram QC
Color: Blue
Rep:31
Fast Willy is on a distinguished road
Send a message via AIM to Fast Willy
please lord tell me you have the truck tuned for the &lbs you are currently running?
Old 12-14-2009, 04:47 PM
Color: graphite
Rep:35
It was dynoed, but I don't have the numbers or anything. The guy I bought it from said it was dynoed to set up the supercharger. I'm really confused on what exactly was done.
Old 12-15-2009, 08:16 PM
RADMAN's Avatar
RADMAN RADMAN is offline
Vehicle: 09 ram
Trim Level: sport
Color: red
RADMAN is on a distinguished road
my buddy have Paxton supercharger on his ram and he is doing his tuning with his predator
Old 12-16-2009, 12:42 AM
Dan's Avatar
Dan Dan is offline
Vehicle: 2009 Dodge Ram 1500
Color: Inferno Red
Rep:27
Dan is on a distinguished road
I would definitely get a custom tune- a predator and a CMR tune would be a good option. That'd give you both the custom tune, and the ability to tweak the tune a little yourself, as well as data logging.
If they reflashed your PCM with a new tune when the supercharger was installed, it might be a bad idea to try to use a regular predator on it (i.e. without a custom tune)- I'm almost certain that the predator doesn't make adjustments to your tune based on whatever was on your PCM before, so if you try to load up one of their standard tunes, you'd be running a supercharged vehicle with a tune intended for stock to mildly modified vehicles. That could yield unpredictable, or even dangerous results.
Old 12-16-2009, 03:13 PM
Fast Willy's Avatar
Color: Blue
Rep:31
You need to get a predator and then have a custom tune don't with that. I really hope you didn't just get a re-flashed ecu. You could be looking a big problems down the road.
