Old 12-19-2009, 12:08 PM
curt4816's Avatar
curt4816 curt4816 is offline
Vehicle: '11 Dodge Ram Crew
Trim Level: Laramie 4X4
Rep:178
curt4816 has a spectacular aura aboutcurt4816 has a spectacular aura about
Originally Posted by curt4816 View Post
Update: I dont have exact numbers yet, but it appears that my mileage may have gone up a bit. my display is reading a higher MPG number and i think i have driven more miles for the amount of fuel used. I will be fueling up tomorrow morning and getting an actual number. I am excited at the potential for increased MPG if i can see a gain as it sits (open filter in engine bay). this weekend i will fab an airbox and see if i net any gains throughout the week week.
......Just filled up, my average was just over a 1 MPG increase over stock.
Mods: H&S Mini Maxx w/ egr and dpf deletes
Old 12-19-2009, 12:19 PM
curt4816's Avatar
Rep:178
Originally Posted by chithead View Post
4 mpg gain by adding heat reflective tape? I would seriously have to see it to believe it. Cooler air would increase HP and MPG, but my initial assumption is that heat reflective tape would just trap hot air under the hood.
I had the same assumption, but this guy tells me that the heat is actually forced out the bottom of the car. the link below is from a turbo BMW that he did. his product reduced the under-hood temps 560 degrees!
http://www.europeancarweb.com/projec...ine/index.html
Old 12-21-2009, 11:34 PM
SPEEDFREAK's Avatar
SPEEDFREAK SPEEDFREAK is offline
Vehicle: 2010 RAM R/T
Trim Level: 450HP & 450TQ
Color: SPEED WHITE
Rep:180
SPEEDFREAK has a spectacular aura aboutSPEEDFREAK has a spectacular aura about
Default Intake
Where did you buy that pipeing, tb opening is 3" 1/4 i couldt find that size of a pipe. Trying to butt them up to each other so it would flow smoothly. Didnt want to have a lip in side of the pipe if i would use 3 1/2".
So the question is is the pipe the same size as the tb? If so were can i buy it?
k&N CAI, 3 1/2" 90 on CAI at TB, 85mm BBK TB,denso sp,180stat,syn oileng & rear gr,Catchcan, Addco sway bars f&r
1 3/4"amer rac hders high flowcats, 2 1/2" H pipe dul 2 1/2" piping, Diablo CT, Bilstin, Mcdrop 2/4,1deg cam 295/45-20bfgkdw,efan,13.4gtech
Old 12-22-2009, 12:41 AM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:432
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
That setup looks great and if I didn't know any better (which I actually don't ) I would have thought it was a kit you got in a box.
Old 12-29-2009, 11:06 PM
curt4816's Avatar
Rep:178
there is actually like a spacer ring around the throttle body to accept the 3.5 opening of the piping.
Old 12-29-2009, 11:12 PM
curt4816's Avatar
Rep:178
you are right, it is a kit from a Chevy that I hacked up and added pieces to make it work. I thought i mentioned this in my earlier posts. not tryin to deceive anyone here. if you look closely at the pics you can see where I cut of the original mounting brackets that didn't apply to my application. everything used to build this intake was purchased at the auto parts store. they sell 90's, 45's, straight pieces and the flexible pieces to assemble anything you want. i just found it cheaper to buy this chevy kit and adapt it.
Old 01-05-2010, 09:42 PM
curt4816's Avatar
Rep:178
Newest update: went on a short camping trip with the family about 3 hrs away from home. got 22 MPG with highway driving only. I was also loaded down with a 4 wheeler and camping equipment. I was impressed. At this point, I have added the heat tape and fabricated an airbox that allows air from the fender well only. the airbox is also covered in the heat tape but I painted it black cause i couldn't stand how it looked. I will be tracking my MPG starting tomorrow.
