Old 12-15-2009, 08:11 PM
mcvoss mcvoss is offline
Gender: Not Specified
mcvoss is on a distinguished road
Default Help on Replacing Power steering hose
Hello,
I have a 99 Ram 1500.I have a leak in the high pressure hose. When removing the hose, the fitting, that connects to the pump, came off. I read somewhere if that happens the internal spring and valve parts will fall out of the pump and they cannot be reinstalled properly. If this occurs the pump needs to be replaced with a new pump. Is this true or can I just put the fitting back on?
Thanks for the help
Old 12-15-2009, 10:02 PM
Rep:1877
I've had that happen before and I just reassemble them.
Old 12-15-2009, 10:05 PM
Sam here , put the spring back in then the spool valve , then the fitting . I believe the fitting is 1" . Secure that first . Then install the line and tighten to spec .
Old 12-16-2009, 01:28 AM
Thanks Guys. I was careful when removing the fitting so the spring and valve are still inside the pump. Do you think I should remove them or will they still be aligned?
Thanks again
Old 12-16-2009, 10:28 AM
Rep:1877
You should be able to just reinstall the fitting as is.
