O2 sensor cause check engine light to come on - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 12-17-2009, 04:44 PM
pike16's Avatar
pike16 pike16 is offline
Vehicle: 2004 dodge ram 5.7
pike16 is on a distinguished road
Exclamation O2 sensor cause check engine light to come on
I have a 2004 ram 5.7 hemi, I recently put a k&n cai, pacesetter long tube headers with not cats and three inch all the way to flowmaster super 44 mufflers, I also have a superchips cortex programmer. My problem is once I instaled the exhause sytem and started the truck my check engine light came on. My programmer says that the O2 sensors are hot, my rear O2 sensors I did not put back on. What can I do to solve the check engine light without putting the cats back on, and will any of this effect the performance and reliability of the truck? Does anyone also know of a place in texas where I can get a custom tune for this truck?
Old 12-17-2009, 06:35 PM
O2 simulators .
Old 12-17-2009, 07:06 PM
pike16's Avatar
Do you know of anywhere I can find O2 simulators? What if I put the 2nd O2 sensor back into the exhaust with spark plug non foulers, will this solve the problem? I have heard of some people doing this. Thanks for your previous suggestion.
Old 12-17-2009, 07:18 PM
Resident Technician
Rep:1915
No, it wont because the downstream O2 sensors are there to monitor catylist efficiency and they would send back the same voltages as the upstream sensors causing a code for a bad converter to set.
Old 12-17-2009, 09:49 PM
Have to have a O2 sensor bung welded in . Then by putting the sensor in a fouler and threading the fouler into the bung takes the sensor out of the exhaust stream . There fore no reading . I haven't seen it done myself , but have been told by several people it works .
Old 12-17-2009, 10:00 PM
Resident Technician
Rep:1915
I can't help but think that installing a resistor between the O2 signal and ground on the 1/2 and 2/2 sensors would be a lot easier than welding a bung into the pipes. It would just be a matter of figuring out the proper resistence.
Old 12-18-2009, 01:25 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
use 2 non foulers per 02 sensor (rear), stuff the bottom one with steel wool, the top one has to be drilled out a little so the 02 sensor can thread in. I have it on mine and i run lt headers, gutted cats, no codes..
Old 12-18-2009, 01:26 AM
chefred112's Avatar
Rep:656
also, what is the exact code that popped up..
Old 12-18-2009, 10:50 AM
pike16's Avatar
Codes that appear:
P0404 egr position sensor performance
P0034 o2 sensor 1/2 heater circuit high
P0058 o2 sensor 2/2 heater circuit high
Old 12-18-2009, 10:54 AM
Resident Technician
Rep:1915
Yup, leaving them off will set those codes. You need to replace that EGR valve too.
