Old 03-17-2011, 04:00 PM
catsltd catsltd is offline
Vehicle: 2010 RCLB SLT 1500 Ram
Color: Mineral Gray
Rep:72
catsltd will become famous soon enough
If you dont have the 02 sims,then your going to have more codes,so buy them and put them on anyway.
Yor code is more of a wiring code,either you burnt a wire,or its hooked up backwards or not all the way plugged in.You should never twist or pull on 02 sensors wires,make sure your header didnt burn the wires.
Front 02 codes are much worse than rear 02 sensor codes,cause they will effect how the truck runs.
The 02 sims are a must with the ARH headers.
Hope that helps a bit.
Good Luck.
2014-True Blue SLT,CC 6.4 BOX.
Air suspension,Rambox,Navigation.Backup camera.
3:92 gears.
Old 03-20-2011, 02:06 PM
E.L.D. 44's Avatar
E.L.D. 44 E.L.D. 44 is offline
Vehicle: 2011 Dodge Ram CC 4x4 Sport
Rep:388
E.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really nice
passenger side wiring extension had a connector pushed out the back. replaced and solved that code. installed O2 plug extensions that I got from Moes and that solved my rear codes. I am code free now! Thanks. I don't know why but I really dont think my MDS was functional with my cel light on. Even when just the rear code was on my gas mileage dropped. Maybe its a new feature on the 11 computer to turn it off with a cel?
MY MOD THREAD
http://www.ramforumz.com/showthread.php?t=87541
