Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Engine Cleaning
Engine Cleaning Cleaning the Engine bay and under body. Degreasing etc.
Old 10-30-2010, 07:07 PM
Kleeeen Kleeeen is offline
Trim Level: 4x4 Sport
Rep:0
Kleeeen is an unknown quantity at this point
How often do you people detail the engine compartment. For me it's a monthly ritual and takes less than 1/2 hr.
Old 11-04-2010, 01:34 PM
M0PARMGNUM's Avatar
M0PARMGNUM M0PARMGNUM is offline
Vehicle: 2000 Dodge Ram RCLB - Auto
Color: Green/silver
Rep:27
M0PARMGNUM is on a distinguished road
I have no specific time schedule on cleaning under the hood of my truck. And where i live its almost pointless to do unless the dirt is really moist and wont fly up. I live in a really dusty area...
But when i do it i make it look like a new one. I do not spray anything down with water or use a degreaser. You do not have to. I just use a microfiber towel damped with Meguiars Natural Shine Protectant to clean off stuff and change out the microfiber towel when needed, then i go over it all again with the Meguiars Natural Shine and use scott shop towels to apply (somtimes ill use a microfiber towel to apply). It works great for me! And you can use it on the fender wells under the hood, i use a microfiber towel on the fenderwells. It takes me over an hour to finish under my hood, i spend alot of time makeing it look new.
Old 08-01-2011, 03:10 PM
DRAM1500's Avatar
DRAM1500 DRAM1500 is offline
Vehicle: 1998 Dodge Ram 1500 4x4 QCSB
Color: RED
Rep:25
DRAM1500 is on a distinguished road
Default Engine Washing
I have washed engines with a pressure washer more than a hundred times, I owned a pressure wash company a while ago.
1 Always cover Alt with plastic bag, & wipe off with damp cloth after washing engine to clean.
2 Never spray directly onto distributor or coil.
3 Cover air intake if open or you have a CAI
4 When done spray all wiring and batt terminals with WD and rest of engine compartment with an Armour All type product and in 15 mins it will look awesome & start right up
5 If using a pressure wash do not go too close to the rad fins
Old 08-07-2011, 05:31 PM
Rangerfied's Avatar
Rangerfied Rangerfied is offline
Rep:14
Rangerfied is on a distinguished road
Send a message via MSN to Rangerfied Send a message via Yahoo to Rangerfied
Originally Posted by chithead View Post
I have been in this habit for years now and have had ZERO issues. Lightly hose down the engine compartment and motor with water, use a rag to wipe off any built up debris, than I lightly hose it off again. With EVERYTHING still wet, I liberally spray Armor All on the motor, air cleaner, fuse box, brake booster, radiator, battery, everything. Shut the hood. Then wash the rest of the truck. When done, open up the hood and tell me if it doesn't look brand new. Next time you do it, that Armor All is still on there and makes it easier to wipe right up. Just my method though.
I mist, wipe, mist, spray, and walk away
I've used this method before on my vehicles too. Never had an issue. Also used some engine cleaner that foams and then you spray off.
Old 08-07-2011, 10:32 PM
yamifz1's Avatar
yamifz1 yamifz1 is offline
Vehicle: 2010 Ram 4x4 Sport
Rep:589
I discovered this method once when I was washing the engine on my bike and a friend had given me some advice on how to get looking like new. This is similar to Chitheads method.
I give the engine a quick rinse down to get the dust off and then I spray the whole compartment with engine de-greaser, let it sit for about 10 minutes and they spray it all off.
Here is the trick, now take a can of tire cleaner, the foaming stuff and spray the whole engine compartment. Once it dries it will be all shiny and new. You will love the results.
RICHARD
Old 02-12-2012, 09:59 AM
ThunderRoadRam's Avatar
ThunderRoadRam ThunderRoadRam is offline
Vehicle: 2005 Dodge Ram 1500 Thunderoad
Color: Gold
Rep:26
ThunderRoadRam is on a distinguished road
to clean mine i will spray the engine off with a normal garden house then spray simple green everywhere then take an old paint brush and work it into the nooks and crannys and then rinse the engine off. ill then let it dry and put a plastic protectant on all the plastic parts
Enforcer
Mopar Mafia
Old 02-12-2012, 10:33 AM
Kong's Avatar
Kong Kong is offline
Vehicle: 2012 Toyota Tundra
Trim Level: SR5
Color: Metalic Grey
Kong is on a distinguished road
I don't trust Simple Green around my truck. I tried cleaning the gunk off my gutters one time with it. It took the paint off them.
The best cleaner I have ever found is called Totally Awesome. Best of all, its only $1.00 a bottle at the dollar store. It's the only product I have found that will even take the black streaks off my camper and and clean my boat, and does great on the siding on my house. Its safe on just about everything, and works great on engines.
Old 03-12-2012, 09:19 PM
Big Green V10's Avatar
Big Green V10 Big Green V10 is offline
Color: Green
Rep:31
Big Green V10 is on a distinguished road
I do what ThunderRoadRam does the same way.
2000 Dodge Ram 2500 4x4 Ext Cab V10, 12" Suspension, 3" Body, 46x19.5x20 Baja Claws
