Old 12-19-2009, 02:46 PM
AMCfreak AMCfreak is offline
Vehicle: 2008 2500
AMCfreak is on a distinguished road
Default My truck looks like it has air shocks out back !!!!
I have an 08 2500HD with a 8' curtis plow, not only does the truck have a terrible rake w/out the plow on it , the plow frame gets very close to the ground with the plow on and raised. I see that there are alot of "leveling kits" available what size should I get (2.5 inches???), and were do I get ones that are fairly high quality ? I would suspect an alignment is required after putting these in, any other considerations?
Old 12-19-2009, 03:08 PM
I have the Daystar 2" on my 1500 .
Old 12-19-2009, 04:09 PM
Rep:1884
Yes, you'll need an alignment when you're finished because the caster angles will change
