V 10 trying to stall - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
Old 12-20-2009, 11:23 PM
badazram's Avatar
badazram badazram is offline
Vehicle: 1995 Ram 2500
Trim Level: Laramie Slt
Color: Green
Rep:72
badazram will become famous soon enough
Default V 10 trying to stall
when i back up slowly and tap the gas to go a little further....the truck tries to stall....the needle dips down to around two hundred RPM and then comes up...I was just wondering what could cause this??
Common sense is genius dressed in its working clothes
Old 12-20-2009, 11:30 PM
Try cleaning the throttle plate and bore with throttle plate cleaner . If you use carb cleaner don't spray it in . Spray a rag and wipe it out .
Old 12-20-2009, 11:36 PM
Resident Technician
Rep:1915
I like using a soft bristle toothbrush for the heavy deposits and following it up with a rag.
Old 12-20-2009, 11:43 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
I totally had this happen recently. I did exactly what tom said, clean your throttle body. I took it off, but if you don't want to do that, you can very easily spray a rag and wipe it down. Open up the flap and wipe down there as well.
Also... In the back of your throttle body is a little motor with a wire harness going into it. there will be 2 hex nut screws, it is your Idle Air Control Valve. Mine had a ton of grime on it, and I cleaned it up with the TB cleaner as well (sprayed onto a rag) and the problem is solved.
Old 12-21-2009, 12:18 AM
badazram's Avatar
Color: Green
Rep:72
hey thanks guys i'll try that and get bac to you sometime....Kev
