Transmission Cooling - 2006 Ram 2500 Diesel - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 12-22-2009, 08:35 PM
Rick2006 Rick2006 is offline
Vehicle: 2006 Dodge Ram 2500 Cummins
Trim Level: xlt
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Rick2006 is on a distinguished road
Question Transmission Cooling - 2006 Ram 2500 Diesel
I bought a used (43,000 miles) 2006 Ram 2500 Heavy Duty quad cab long bed to pull a 10,000 pound 5th wheel trailer. I picked up information from various sources indicating that additional transmission cooling would extend the life of the transmission. What are the pros / cons of adding more cooling capacity? Or, will regular transmission maintenance be just as good as more cooling?
If this question has already been answered, please steer me to the thread/posting.
FYI - This is my first pick-up truck and first diesel engine. So far so good. I am following Dodge maintenance intervals and using Cummins Stratopore oil filters and Cummins fuel filter elements.
Old 12-22-2009, 09:07 PM
Resident Technician
Rep:1915
We haven't seen any heat related transmission failures at my dealership. Additional cooling likely won't hurt anything but it will prolong the time it takes the fluid to get to normal operating temps. Regular maintainence should keep your trans in good shape for a long time to come.
Old 12-28-2009, 04:28 PM
Trim Level: xlt
Default Transmission cooling
Remerson228
Thanks for the response - unless I find some definitive information on heat-related transmission failures I will stick with regular maintenance. With the proper care I do expect a long life from this Dodge/Cummins truck.
Rick
Old 12-28-2009, 04:33 PM
Resident Technician
Rep:1915
Take a look at this thread.... http://www.ramforumz.com/showthread.php?t=44780
Old 12-28-2009, 05:42 PM
Your truck should have heavy duty cooling anyway . If you need to install a trans cooler , I would recommend you go with a factory unit . I have installed them on several Rams . Easy to install , and looks great when done .
Old 12-30-2009, 06:05 PM
Trim Level: xlt
I have not had any overheating problems - but I have yet to tow my RV in the summer. Thanks for the input on the factory cooler. I will keep close track of the transmission fluid condition.
Does the trans on an '06 2500 diesel require manual adjustments of bands or internal parts?
Old 12-30-2009, 06:15 PM
Trim Level: xlt
Originally Posted by Remerson228 View Post
800,000 miles - and I assume that is without a rebuild. Wow. Do you recommend maintenance that goes beyond the factory manual?
By the way, what is a lift pump?
Old 12-31-2009, 10:18 PM
m88tow m88tow is offline
Vehicle: 2000 Dodge Ram 2500 4x4
m88tow is on a distinguished road
Probally referring to fuel pump on the frame rail that gets the fuel to the motor.
Old 12-31-2009, 10:25 PM
Resident Technician
Rep:1915
If you follow the maintainence schedule for severe service, you should be fine. Regular adjustments aren't normally required but it is possible. The lift pump is the electric pump in the tank that pushes fuel to the injector pump.
Old 01-01-2010, 02:10 AM
Pretty sure the lift pump is not in the tank.
rick in arizona
