Truck stalled while putting gas in - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 12-23-2009, 09:51 AM
blackknight04 blackknight04 is offline
Vehicle: 04 ram 1500
blackknight04 is on a distinguished road
Default Truck stalled while putting gas in
i know your not suppose to have it running anyways but it was sleeting and cold out at the time,anyways i was filling up my truck and just before it got full it shut off.i didnt think anything of it at first just maybe my girlfriend shut it off for some reason.i get in and it wouldnt start and all it would do is crank.i just put the pedal down a little bit and it started.about a couple blocks down the road it almost died again when i let of for a stop light and i just blipped the gas and it was fine.has anyone else had any problems like that before?
thanks
Old 12-23-2009, 09:53 AM
Resident Technician
Rep:1915
First thing I'd do is check for any PCM codes and then inspect the throttle body for buildup. I'm fairly certain it's dirty, so get some throttle body or brake cleaner, an old toothbrush and a rag and clean it out good and see if that doesn't help.
Old 12-23-2009, 10:29 PM
Fuzznutts's Avatar
Fuzznutts Fuzznutts is offline
Vehicle: 2010 Dodge Ram 1500 QC
Trim Level: Bighorn Edition
Rep:25
Fuzznutts is on a distinguished road
You may have filled up with gas that has some water in it.
I had that happen last year in Iowa at Christmas.
I had to add a can of Heat water remover to the tank to cure it.
Old 12-23-2009, 10:35 PM
And you sucked air into your fueling system with the cap off and the engine running....
Old 12-24-2009, 01:40 AM
Strange . Your battery hasn't gone dead here recently has it ? Could of wiped the memory from the computer . Have seen this happen before .
Old 12-24-2009, 04:17 AM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
Man, I wish you spared one of your three Christmas wishes...
Old 12-24-2009, 09:21 AM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
Sounds like it could be a vapour lock/air in the line>? Filling the tank running was it close to empty?
Old 12-24-2009, 09:22 AM
hemitastic's Avatar
hemitastic hemitastic is offline
Vehicle: 2004 Dodge Ram 1500 Daytona
Trim Level: slt?
Color: silver
hemitastic is on a distinguished road
mines stalled for no reason the other day and some times its turns over slow if i dont have the key cranked all the way it takes a few clicks to turn over
Old 12-25-2009, 12:43 PM
it had about a 1/4 tank left when i filled it up.i really dont know to much about it as i just bought it a week ago and it came with 3/4 tank of gas.thanks for the replies
Old 12-30-2009, 09:01 AM
hemitastic's Avatar
Trim Level: slt?
Color: silver
mine just stalled again last night? right after a i started it up and moved 100 yards
