Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 12-23-2009, 03:40 PM
Rep:2616
Default Radiator fin protection
i need some advice i'm hoping someone has an idea how i can prevent debris, like hay, bees, & butterflies, from getting in between the fins on my 2009 Dodge Ram, on my last pilot vehicle i was easily able to access the front of the radiator & hang a open mesh window screen in front of the radiator & not in front of the grill. ( on older Dodge trucks, the grill is part of the hood & gives great access, for mounting & cleaning ) I drive in all sorts of terrain, mostly the desert roads & I have to continually either blow out the debris from the radiator , or just wash off the screen anyone have ideas??
Last edited by GTyankee; 12-23-2009 at 03:41 PM. Reason: i think i forgot to use the space bar :(
Old 12-23-2009, 04:48 PM
wvcoolvinilla wvcoolvinilla is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x4
Trim Level: Outdoorsman - Rambox
Color: Black Crystal - Gray
Rep:83
wvcoolvinilla will become famous soon enough
you got something going there.. my problem is when i go to the car wash to clean the raditor the fins bend while i am trying to get the bee's and other big bugs cleaned out..
Old 12-23-2009, 05:13 PM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:432
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
This is a great idea that you have. I think I'm going to work on this for my truck. I was thinking of getting some of this type of mosquito/bug netting that's on the sliding glass doors. Maybe making some kind of frame to hold it in place right behind the grill.
I don't think this will obstruct too much air flow will it? And it's great for keeping bugs off the radiator.
Old 12-23-2009, 05:27 PM
michael99's Avatar
michael99 michael99 is offline
Vehicle: 1999 Dodge Ram 1500
michael99 is on a distinguished road
Tom's Blue Ram or Remerson 228 will probabley know more about this than I do, but there is a brush you can get that will clean debris out from between the fins and even straighten out the bent ones. I have seen mechanics use them on my Peterbilt but I'm not sure what they are called or where to get them.
1999 Dodge Ram 1500 4X4, 5.9l V8 360, Airaid CAI, Extang Tuff Tonneau, SS Tubular Nerf Bars,
Flowsound single chamber exhaust duals out the rear
Old 12-23-2009, 05:29 PM
Rep:83
thanks for the post michael i hope some one can hook us up
Old 12-23-2009, 05:42 PM
michael99's Avatar
Anytime. If you call advance or napa they may know what I'm talking about.
Old 12-23-2009, 11:40 PM
I like the idea of the screen . Hopefully you can come up with a setup thats easy to install and clean . I would definitely be real careful if you use a pressure washer on the radiator fins . Yes they bend over very easy . There is a tool "condensor comb" , I believe thats what it's called . I use a small flat blade screwdriver sometimes . Works well just a little time consuming . I use a pressure washer at work for cleaning the cores on my heavy equipment . But those fins are quite ridgid and hard to bend over . You may want to consider using a condensor cleaning agent . You spray it on with a squirt bottle , let it sit , then hose it off . Works great . Let me know how you make out . Tom
Old 12-24-2009, 04:00 AM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
What year/model is your Pete? They build kick-ass trucks. 379s are the shiz. I used to like Kenworth until the ugly ass T2000 came out.
Now wouldn't that mosquito screen catch on fire with the heat coming from the engine?
Old 12-24-2009, 08:54 AM
michael99's Avatar
Its a 98 378 day cab. Its pretty mch the same as athe 379 except the hood is a little shorter. I have a pic of it in my ablum (Nighttime gotta love those lights). lol
Old 12-24-2009, 09:25 AM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
I think the screen is a great idea. You have alot of room in the front of these rams to be able to work. I thought i seen a brush at our local Napa . I will try and check it out. It was in the auto maint/cleaning section.
